6594 Discussions
Problem with movidius stick (1 version) with SDK 2.0 - Exception: Status.INVALID_DATA_LENGTH
Hi all
I trained a custom network with Keras. Then, with a script, I converted my keras model to tensorflow and with mvnCCompiler, I got the related graph file.
When i run the inference, with _ graph.allocate_with_fifos_ and graph.queue_inference_with_fifo_elem specifying the input tensor, I get the following error
E: [ 0] ncFifoWriteElem:2608 input tensor length (59040) doesnt match expected value (19680)
I made many attempts without arriving at a solution. Can you help me ?
thanks a lot
Hi @gtr91
What were your input dimensions? Are you using NCSDK v1 or v2?
Sahira
Hi @Sahira_at_Intel
thank you for the response.
Input dimensions are (60,41,2) and i'm using NCS v1 with NCSDK v2.
Hi @gtr91
Can you please attach your Keras model, the converted .pb file, and the script you used to convert it. Also, what command + parameters did you use when compiling using mvNCCompile?
Sahira
Hi @Sahira_at_Intel
I sent you the files you requested with private message.
Thank you so much
