6584 Discussions
Problems confront fllowing Guidance for Compiling TensorFlow Networks
Hi there,
Currently, being a rookie in this field, I've been following the compiling steps "Guidance for Compiling TensorFlow Networks" on the website of Intel Movidius. However,I confront problems using SPYDER by only deal with the sample guidance gave.
I've successed the step creating three files : mnist_model.index, mnist_model.data-00000-of-00001, mnist_model.meta. But when I tried to modifiy mnist_deep.py into mnist_deep_inference.py
The mnist_deep_inference.py looks like this : https://ideone.com/RSAE2H
the console in spyder gives me this error message: https://ideone.com/sxzKwP
when I check the folder i am working on, I was puzzled why I still have created : mnist_inference.index, mnist_inference.data-00000-of-00001, mnist_inference.meta.
Then I tried to type the "mvNCCompile" command in the console of spyder, it tells me that the command is invalid syntax (but I had installed the ncsdk tool kit).
Can someone help me with this situation, please? :'(
Hi @yi-ru
I have not tried using the Neural Compute SDK with SPYDER. Could you try installing the NCSDK without using SPYDER and see if you get the same results?
Jesus
Thank you for responding me!!
I tried to use NCSDK to compile mnist_deep_inference.py
however this is the message I got on my pc:
https://ideone.com/78rPLa
Really need your help :'(
Thank you
Hi @yi-ru
I believe this is a known issue with the NCSDK v2.10, could you try using the NCSDK v2.08?
Jesus
