6597 Discussions
Problems using Faster RCNN TFODAPI converted
Jordan_RJ
I converted a first model (trained on a custom dataset) from TFODAPI (TF == 2.6) using OpenVINO (stack : 2121.4.752), it was an : SSD 50. After converting it, I successfuly used it using : object_detection_sample_ssd.py
I did conversion using :
python3 <path_to>/mo_tf.py \
    --saved_model_dir <path_to>/saved_model/ \
    --transformations_config <path_to>/model_optimizer/extensions/front/tf/ssd_support_api_v2.4.json \
   --tensorflow_object_detection_api_pipeline_config <path_to>/my_ssd_resnet50_v1_fpn/pipeline.config \
  --input_shape [1,640,640,3]
I tried conversion of faster RCNN 152 (trained on a custom dataset) in the same way:
--saved_model_dir <path_to>/my_faster_rcnn_resnet152/saved_model/ \
--transformations_config ../../faster_rcnn_support_api_v2.4.json \
--tensorflow_object_detection_api_pipeline_config <path_to>/my_faster_rcnn_resnet152/pipeline.config \
--input_shape [1,1333,1333,3]
When trying to convert fatser_RCNN 152, I get following error :
[ ERROR ] Exception occurred during running replacer "ObjectDetectionAPIProposalReplacement" (<class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIProposalReplacement'>): The matched sub-graph contains network input node "input_tensor".
Could you help me to debug this ?
Respectfully
Peh_Intel
Hi Jordan,
I’ve validated that the pre-trained model, Faster R-CNN ResNet152 V1 1024x1024 from TensorFlow 2 Detection Model Zoo can be successfully converted into Intermediate Representation (IR).
We would like to request your custom model (saved_model and pipeline config) for further investigation.
Peh
Jordan_RJ
Is it possible to send that in private ?
Also, I tried from model-zoo too and got following ouput :
 ERROR ]  Please contact Model Optimizer developers and forward the following information:
[ ERROR ]  Exception occurred during running replacer "ObjectDetectionAPIPreprocessor2Replacement (<class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIPreprocessor2Replacement'>)":
[ ERROR ]  Traceback (most recent call last):
  File "/<PATH>/hpml/openvino/install/intel/openvino_2021.4.752/deployment_tools/model_optimizer/mo/utils/class_registration.py", line 276, in apply_transform
    replacer.find_and_replace_pattern(graph)
  File "/<PATH>/openvino/install/intel/openvino_2021.4.752/deployment_tools/model_optimizer/mo/front/tf/replacement.py", line 36, in find_and_replace_pattern
    self.transform_graph(graph, desc._replacement_desc['custom_attributes'])
  File "/<PATH>/openvino/install/intel/openvino_2021.4.752/deployment_tools/model_optimizer/extensions/front/tf/ObjectDetectionAPI.py", line 710, in transform_graph
    assert len(start_nodes) >= 1
AssertionError
Peh_Intel
Hi Jordan,
Yes, you can privately send your model to my email:
yux.chern.peh@intel.com
Regarding the TensorFlow 2 Detection Model, you have to use faster_rcnn_support_api_v2.0.json as they are trained using TensorFlow Object Detection API version 2.2.
Peh
Jordan_RJ
Thank you for your answer, I will come back to you by email with pretrained model, as soon as I have verifier that my problem was not just about using V2.4 instead of v2.0
Respectfully
Peh_Intel
Hi Jordan,
I do not receive your custom model in my email so far. Does it mean you already able to convert your model?
Peh
Peh_Intel
Hi Jordan,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Peh
Bharat_Sharma
I am facing this exact issue when converting my custom trained faster rcnn model to openvino IR.I am using openvino version -
openvino 2021.4.2
openvino-dev 2021.4.2
I tried using the faster_rcnn_support_api_v2.0.json and it gives me this error -
[ WARNING ] Model Optimizer removes pre-processing block of the model which resizes image keeping aspect ratio. The Inference Engine does not support dynamic image size so the Intermediate Representation file is generated with the input image size of a fixed size.
[ WARNING ] The model resizes the input image keeping aspect ratio with min dimension 800, max dimension 1333. The provided input height 800, width 1333 is transformed to height 1333, width 1333.
[ ERROR ] -------------------------------------------------
[ ERROR ] ----------------- INTERNAL ERROR ----------------
[ ERROR ] Unexpected exception happened.
[ ERROR ] Please contact Model Optimizer developers and forward the following information:
File "/home/bharat/projects/fuelmatics-lid-detection/env/lib/python3.8/site-packages/mo/mo/utils/class_registration.py", line 276, in apply_transform
File "/home/bharat/projects/fuelmatics-lid-detection/env/lib/python3.8/site-packages/mo/mo/front/tf/replacement.py", line 36, in find_and_replace_pattern
File "/home/bharat/projects/fuelmatics-lid-detection/env/lib/python3.8/site-packages/mo/extensions/front/tf/ObjectDetectionAPI.py", line 710, in transform_graph
AssertionError
The above exception was the direct cause of the following exception:
File "/home/bharat/projects/fuelmatics-lid-detection/env/lib/python3.8/site-packages/mo/mo/main.py", line 394, in main
ret_code = driver(argv)
File "/home/bharat/projects/fuelmatics-lid-detection/env/lib/python3.8/site-packages/mo/mo/main.py", line 356, in driver
ret_res = emit_ir(prepare_ir(argv), argv)
File "/home/bharat/projects/fuelmatics-lid-detection/env/lib/python3.8/site-packages/mo/mo/main.py", line 252, in prepare_ir
graph = unified_pipeline(argv)
File "/home/bharat/projects/fuelmatics-lid-detection/env/lib/python3.8/site-packages/mo/mo/pipeline/unified.py", line 13, in unified_pipeline
class_registration.apply_replacements(graph, [
File "/home/bharat/projects/fuelmatics-lid-detection/env/lib/python3.8/site-packages/mo/mo/utils/class_registration.py", line 328, in apply_replacements
apply_replacements_list(graph, replacers_order)
File "/home/bharat/projects/fuelmatics-lid-detection/env/lib/python3.8/site-packages/mo/mo/utils/class_registration.py", line 314, in apply_replacements_list
apply_transform(
File "/home/bharat/projects/fuelmatics-lid-detection/env/lib/python3.8/site-packages/mo/mo/utils/logger.py", line 111, in wrapper
function(*args, **kwargs)
File "/home/bharat/projects/fuelmatics-lid-detection/env/lib/python3.8/site-packages/mo/mo/utils/class_registration.py", line 302, in apply_transform
raise Exception('Exception occurred during running replacer "{} ({})": {}'.format(
Exception: Exception occurred during running replacer "ObjectDetectionAPIPreprocessor2Replacement (<class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIPreprocessor2Replacement'>)":
When i use the faster_rcnn_support_api_v2.4.json, i get a different error which is the same as mentioned by @Jordan_RJ  in the beginning.
This is the python command that runs -
python env/lib/python3.8/site-packages/mo_tf.py --saved_model_dir=exported_models/faster_rcnn/saved_model --output_dir=openvino/faster_rcnn --transformations_config=env/lib/python3.8/site-packages/mo/extensions/front/tf/faster_rcnn_support_api_v2.0.json --tensorflow_object_detection_api_pipeline_config=exported_models/faster_rcnn/pipeline.config --input_shape="[1, 800, 1333, 3]"
Help in this would be really appreciated. @Peh_Intel
Bharat
Peh_Intel
Hi Bharat,
Thanks for submitting a new question in the following thread:
https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/Trouble-exporting-faster-rcnn-model-to-openvino-IR-format/m-p/1434767
Peh
