Promblem when set up
My Ubuntu is Ubuntu 16.04.5. I didn't use any conda enviroment.
When I enter make install ,the log is followed:
`./uninstall-opencv.sh
make install starting.
./install.sh
--2019-01-11 10:14:20-- https://downloadmirror.intel.com/28192/eng/NCSDK-1.12.01.01.tar.gz
Resolving child-prc.intel.com (child-prc.intel.com)… 10.239.4.80
Connecting to child-prc.intel.com (child-prc.intel.com)|10.239.4.80|:913… connected.
Proxy request sent, awaiting response… 200 OK
Length: 966651 (944K) [application/x-gzip]
Saving to: ‘NCSDK-1.12.01.01.tar.gz’
NCSDK-1.12.01.01.ta 100%[===================>] 944.00K 394KB/s in 2.4s
2019-01-11 10:14:23 (394 KB/s) - ‘NCSDK-1.12.01.01.tar.gz’ saved [966651/966651]
NCSDK-1.12.01.01/
NCSDK-1.12.01.01/ncsdk-x86_64/
NCSDK-1.12.01.01/ncsdk-x86_64/udev/
NCSDK-1.12.01.01/ncsdk-x86_64/udev/97-usbboot.rules
NCSDK-1.12.01.01/ncsdk-x86_64/api/
NCSDK-1.12.01.01/requirements_apt.txt
Movidius Neural Compute Toolkit Setup.
Checking OS and version…
Your current combination of linux distribution and distribution version is not officially supported!
Hi @Delia
Do you have the 32-bit version of Ubuntu 16.04?
You can see which version you have by going to Settings > Details
Sahira
It's 64-bit version of Ubuntu16.4 :'(
Is there any other way to fix it except rebuild the system?
Hi @Delia
Can you run the command lsb_release -a? If not, you don't have the lsb_core package. To install the package, run sudo apt-get install lsb-core.
Then try to reinstall the NCSDK again. Please let me know if this information was helpful
Sahira
I can't install lsb-core. The log is followed:
Reading package lists… Done
Building dependency tree
Reading state information… Done
lsb-core is already the newest version (9.20160110ubuntu0.2).
0 upgraded, 0 newly installed, 0 to remove and 7 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up lsb-core (9.20160110ubuntu0.2) …
/var/lib/dpkg/info/lsb-core.postinst: 66: /var/lib/dpkg/info/lsb-core.postinst: py3compile: not found
dpkg: error processing package lsb-core (--configure):
subprocess installed post-installation script returned error exit status 127
Errors were encountered while processing:
lsb-core
E: Sub-process /usr/bin/dpkg returned an error code (1)
When I type:lsb_release -a.
The log is:
bash: /usr/bin/lsb_release: /usr/bin/python3: bad interpreter: No such file or directory
I have fixed the upper problem.
But when I type:lsb_release -a.
The log is:
ModuleNotFoundError: No module named 'lsb_release'
When I type :sudo apt-get install lsb-core
The log is:
Then I make install again,The Error is the same:
Hi @Delia
According to the output log: /var/lib/dpkg/info/lsb-core.postinst: 66: /var/lib/dpkg/info/lsb-core.postinst: py3compile: not found, I think your python3 installation is corrupted. Try re installing your python3 module, then re installing the NCSDK.
Sahira
I have fixed the python3.
The log is:
The log is:
@Delia @Sahira_at_Intel ,
Another way to check the Ubuntu version is with the following command: cat /etc/*release. Not sure what could be causing the problem, hopefully we can narrow it down and fix it. May I ask which version of the NCSDK are you trying to install (v1 or v2)? By any chance do you have OpenCV built and installed prior installing the NCSDK?
@Luis_at_Intel
