6597 Discussions
Proxy Configuration on Installing with Docker
Hi there,
I have some confuses on installing NCSDK with Docker. Is it necessary of proxy configuration when installing with Docker? If it is not necessary, maybe we could add some hints (e.g., "optional") at the end of the title?
Hi @yungshenglu
You only need to do a proxy configuration if you are using Docker behind a proxy. If not, you can continue with the regular installation instructions.
Sahira
Hi @Sahira_at_Intel
Thanks for your help! :)
Best,
Yung-Sheng Lu
