Python error on Raspbian 2019.1: ImportError: No module named 'openvino'
Keyes__Mike
I'm trying to use openvino in Python on Raspbian Stretch. I installed on a fresh OS using the instructions on this page: https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_raspbian.html  All went well, and the demos ran correctly.
My python scripts (and the included scripts in /opt/intel/openvino/deployment_tools/inference_engine/samples/python_samples) error out on the openvino import statement:
I did set up setupvars.sh to load automatically when the terminal opens and I see the "[setupvars.sh] OpenVINO environment initialized" message as expected.
How to fix?
Shubha_R_Intel
Dear Mike, this error always happens when setupvars.sh[bat] was not executed. And you did the right thing by placing your python scripts in /opt/intel/openvino/deployment_tools/inference_engine/samples/python_samples.
Can you retry this time with the manual method - i.e. open up a shell, run the setupvars.sh manually ? If this works, then it must be an error in your automated method.
Thanks kindly,
Shubha
Keyes__Mike
Thanks for the reply. setupvars.sh was running, after opening the terminal I was able to run commands like "echo $PYTHONPATH" and see values set in the setupvars.sh script, and I was able to see modified values of PYTHONPATH after I changed setupvars.sh and restarted terminal. However, this did not solve my problem.
After some fooling around I was able to get my scripts to run by copying openvino into my dist-packages folder using:
sudo cp -R /opt/intel/openvino/python/python3.5/armv7l/openvino /usr/local/lib/python3.5/dist-packages
Shubha_R_Intel
Dear Keyes, Mike,
Glad you solved it. Thanks for using OpenVino !
Shubha
Wios__Ed
Something not quite right here, I've got the same error straight out of a fresh 2019.1 installation on the Raspbian Stretch. I did something similar as Keyes did by linking openvino one level up and problem solved:
sudo ln -s /opt/intel/openvino/python/python3.5/armv7l/openvino/ /opt/intel/openvino/python/python3.5/openvino
nah@dontbother:/opt/intel/openvino/python/python3.5 $ ls
armv7l  cv2.cpython-35m-arm-linux-gnueabihf.so
nah@dontbother:/opt/intel/openvino/python/python3.5 $ python3 -c "import openvino"
  File "<string>", line 1, in <module>
nah@dontbother:/opt/intel/openvino/python/python3.5 $ sudo ln -s /opt/intel/openvino/python/python3.5/armv7l/openvino/ /opt/intel/openvino/python/python3.5/openvino
armv7l  cv2.cpython-35m-arm-linux-gnueabihf.so  openvino
Shubha_R_Intel
Dear folks,
I have filed a bug on this issue, so hopefully you won't see it in the next OpenVino release !
Thanks for your patience,
Shubha
tuaf__izack
Hi Keyes, Mike,
Thanks for the fix!
it helped me with the same error on a raspberry after executing setupvars.sh with OpenVino 2019 R1 :)
Chen__Bofu
Hi all, I made a Debian package for OpenVINO RPi, and it can be installed by the following steps:
$ curl -sL https://raw.githubusercontent.com/DT42/BerryNet-repo/master/setup.sh | sudo -E bash -
$ sudo apt install openvino-rpi
For more details, please refer to https://github.com/DT42/BerryNet-repo
cesar_diaz_col
Hi!,
I'd like to get some help about this problem using Intel® Distribution of OpenVINO™ toolkit 2021.2 for Intel NCS2 connected to Raspberry PI 4 (raspbian)
When I try to run this code:
https://github.com/glennford49/ObjectDetection_openvino
Models: https://www.mediafire.com/file/o6ecf6txs8p1aui/model.zip/file
Video: https://www.youtube.com/watch?v=kptX-BsDNy0
I had this errors:
from openvino.inference_engine import IENetwork, IECoreModuleNotFoundError: No module named 'openvino'
When I explored the opt/ directory, the armv71 directory doesn't exists.
/opt/intel/openvino/python/python3.7/armv7l
What can I do with that?. Thanks!
