Quantization 8bit for yolov4
Kartikeya
I am trying to convert fp32 yolo model(trained on custom classes) into an int8 low precision quantized model. However upon conversion I am unable to see any bounding boxes(unlike fp32/fp16) when I try to do inference even though .xml and .bin files are generated. I have tried Default and Accuracy aware training both. I am able to achieve the conversion through command line tools. DL Workbench does not convert to int8 IR also.
How can I tackle the above problem?
Sebastian_M_Intel
Hello Kartikeya,
Thank you for posting on the Intel® communities.
Based on what you are reporting this seems to be related to the OpenVINO™ toolkit, we will move this thread to the proper sub-forum for better assistance and kindly wait for a response.
Sebastian M
Intel Customer Support Technician
IntelSupport
Community Manager
Thanks for reaching out.
Yolov4 is not validated with OpenVINO. Only yolov1,yolov2 and yolov3 are validated. The information is available in the following page :
https://docs.openvinotoolkit.org/latest/openvino_docs_MO_DG_prepare_model_convert_model_tf_specific_Convert_YOLO_From_Tensorflow.html#yolov3-to-ir
The following page contains the list of topologies that have been validated for 8-bit inference feature.
https://docs.openvinotoolkit.org/latest/openvino_docs_IE_DG_Int8Inference.html#low_precision_8_bit_integer_inference_workflow.
There are three Yolo models (TensorFlow Yolov3,Caffe Yolo v1 tiny and Caffe Yolov3 ) in the above list.
I suggest you use any of these models for post training quantization
Here is an additional reference regarding the workflow of converting a model from FP32 to INT8:
https://docs.openvinotoolkit.org/latest/workbench_docs_Workbench_DG_Int_8_Quantization.html
Aznie
IntelSupport
Community Manager
Hi Kartikeya,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Aznie
