Question on emmintrin.h header file
Joel_E_
I had some errors during compilation of OpenVino samples on my older i7 CPU (i7 870 to be exact).
The compilation error was related to _mm_blendv_ps which was introduced on SSE4.1 technology according to this documentation.
This was solved by changing "defs.h" include file from emmintrin.h (SSE2) to either smmintrin.h (SSE4.1) or nmmintrin.h (SSE4.2).
Obviously _mm_blendv_ps was introduced from SSE4.1 so I was wondering why emmintrin.h was used? Is this a bug?
Any instructions/advice instead if the current solution is not advisable.
Thanks in advance.
Joel
berupon
Hi, Joel E. Thanks a lot for the medium post. It helped me to solve the problem with VS2017.
Regarding the header file to include,
  MSVC : <intrin.h>
  gcc/clang : <x86intrin.h>
might be preferrable. It seems like x64 gcc/clang also has <intrin.h> but x86 gcc/clang lack it.
Anyways, <intrin.h> file contains include statements for non-x86 processors such as <arm_neon.h>, which can be a taboo for the bunnysuits.
Joel_E_
Hi berupon,
Thanks for your reply! It's good to know about the other header files related to MSVC and gcc.
Hope others will also find this useful.
Joel
