6597 Discussions
Re: Error while converting PMTD ONNX model to OpenVino IR
Sharma__Divyanshu
Continuation of: https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/Custom-Implementation-for-ScatterND-op/m-p/1201227#M20318 since it is no longer being monitored.
Hi @Max_L_Intel and @Munesh_Intel !
I get the same error despite building the latest version of the model_optimizer from GitHub. I have attached the error log below
Thanks a lot for helping with this. It is kind of urgent.
Max_L_Intel
Hi @Sharma__Divyanshu
We tested your model with OpenVINO Github release, but we don't see errors related to ScatterND. The support for ScatterND should be already implemented.
However, there is different error related to unsupported Resize-11 operation:
Model Optimizer arguments:
Common parameters:
	- Path to the Input Model: 	/home/user/Downloads/PMTD_FINAL 1.onnx
	- Path for generated IR: 	/home/user/Downloads/openvino_new/openvino/model-optimizer/.
	- IR output name: 	PMTD_FINAL 1
	- Log level: 	ERROR
	- Batch: 	Not specified, inherited from the model
	- Input layers: 	Not specified, inherited from the model
	- Output layers: 	Not specified, inherited from the model
	- Input shapes: 	Not specified, inherited from the model
	- Mean values: 	Not specified
	- Scale values: 	Not specified
	- Scale factor: 	Not specified
	- Precision of IR: 	FP16
	- Enable fusing: 	True
	- Enable grouped convolutions fusing: 	True
	- Move mean values to preprocess section: 	False
	- Reverse input channels: 	False
ONNX specific parameters:
Model Optimizer version: 	unknown version
[ ERROR ]  Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.load.onnx.loader.ONNXLoader'>): Unexpected exception happened during extracting attributes for node Resize_175.
Original exception message: ONNX Resize operation from opset 11 is not supported.
Resize Opset-11 operation is currently not supported by Model Optimizer to convert.
OpenVINO team is working on adding support for Resize-11. There are some PRs related to this already: operation specification and support for the operation in the Model Optimizer
As possible workaround you can try to use other Resize-like operation and convert the model with Opset-10.
Max_L_Intel
Can you please share your model with us, so we try to reproduce this from our end?
Please also note the is being new feature that has been just implemented but not yet verified, hence for the time being we can't guarantee this works as expected.
Sharma__Divyanshu
Hi @Max_L_Intel !
Do you have an email ID I could send it on. I don't think I'm allowed to post it on a public forum.
Thanks!
Max_L_Intel
We have sent you an email. Please check it.
Max_L_Intel
Common parameters:
	- Log level: 	ERROR
Sharma__Divyanshu
Hi @Max_L_Intel ! Thanks for checking out the model. I can't use Opset 10. I get the error:
RuntimeError: Unsupported: ONNX export of index_put in opset 9. Please try opset version 11.
Anyway, since my entire model only requires an upscale factor of 2, I managed to get Resize working for Opset 11 by hardcoding the output shape (By editing the Upsample.py). Once that was done, I commented the code which throws the exception for Resize not being supported in Opset 11. I've successfully tested that this works in a model I converted before (Compared output of PyTorch and OpenVino model).
Attached below are the files I changed. Perhaps you could try converting the model with these files. I get the ScatterND error once this is done.
1. openvino\model-optimizer\extensions\front\onnx\resize_ext.py
2. openvino\model-optimizer\extensions\ops\upsample.py
Thanks a lot!!
Max_L_Intel
I don't think we could support such method. We tested the files you attached, and we see the same error.
I recommend to wait until Resize-11 support is implemented from OpenVINO side. And please also note that ScatterND support is new feature that has been implemented just recently but not yet fully verified, hence for the time being we can't guarantee this works as expected.
We apologize for the inconvenience.
Max_L_Intel
If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
