Re: segmentation_demo doesn't work
Benguigui__Michael
I am currently trying to perform cloud segmentation on 28x28 patches, by using "segmentation_demo.py" (open_model_zoo 2022.1.0).
Right before, I converted my ONNX model using "mo.py" (openvino 2022.1.0). I tested many paramaters at the conversion and inference level, but I can not get correct prediction masks as results (Outputs.zip attached). Any idea ?  I get similar results whatever the device (CPU, Myriad). I also attached:
- the ONNX model (model.LeNet_FCN.0.202205100731.28x28 ONNX.zip)
- the H5 model (model.LeNet_FCN.0.202205100731.28x28 H5.zip) converted to ONNX via "tf2onnx.convert"
- some input images (Inputs.zip) ...
-  ... with ground truth masks (GroundTruth.zip).
Thanks in Advance++
Wan_Intel
Hi Benguigui__Michael,
For your information, LeNet_FCN.0.202205100731.28x28 is not validated on Image Segmentation Python Demo.
The supported models for Image Segmentation Python Demo are as follows:
1. architecture_type = segmentation
    o  deeplabv3
    o  drn-d-38
    o  fastseg-large
    o  fastseg-small
    o  hrnet-v2-c1-segmentation
    o  icnet-camvid-ava-0001
    o  icnet-camvid-ava-sparse-30-0001
    o  icnet-camvid-ava-sparse-60-0001
    o  ocrnet-hrnet-w48-paddle
    o  pspnet-pytorch
    o  road-segmentation-adas-0001
    o  semantic-segmentation-adas-0001
    o  unet-camvid-onnx-0001
2. architecture_type = salient_object_detection
    o  f3net
Wan
Accelerator
If I understand correctly, we can't use any custom architecture? Even 2 layers of convolution with an activation ?
Wan_Intel
Thanks for your question.
This thread will no longer be monitored since we have provided suggestions.
If you need any additional information from Intel, please submit a new question.
Wan
