6595 Discussions
ReLU operation is giving output as expected
I am trying to implement Max Pooling followed by ReLU, but i noticed my output is incorrect for the ReLU,
here is my relu.prototxt
input: "data"
input_shape
dim: 1
dim: 1
dim: 1
dim: 5
layer {
type: "Pooling"
bottom: "data"
top: "pool"
pooling_param {
pool: AVE
kernel_size: 1
stride: 1
layer {
type: "ReLU"
bottom: "pool"
top: "pool"
can some one help me… is this prototxt file correct?
@murthysristi If you are referring to the "top" parameter of your pool_relu layer, I usually see the output layer's "top" value being set to itself. I ran a quick mvNCCheck on this model and I did not have any issues.
Tome , Can you share prototxt file and the mvNCCheck results?
I was using your prototxt file above as a base. Since you said you wanted MAX pooling followed by ReLu, I modified your prototxt file as such:
name: "max_pooling_relu_net" input: "data" input_shape { dim: 1 dim: 1 dim: 1 dim: 5 } layer { name: "pool" type: "Pooling" bottom: "data" top: "pool" pooling_param { pool: MAX kernel_size: 1 stride: 1 } } layer { name: "pool_relu" type: "ReLU" bottom: "pool" top: "pool_relu" }
Here are the mvNCCheck results:
mvNCCheck v02.00, Copyright @ Movidius Ltd 2016 ****** WARNING: using empty weights ****** USB: Transferring Data... USB: Myriad Execution Finished USB: Myriad Connection Closing. USB: Myriad Connection Closed. Result: (1, 1, 5) 1) 3 0.912 2) 4 0.8667 3) 2 0.0 4) 1 0.0 5) 0 0.0 Expected: (1, 1, 5) 1) 3 0.912 2) 4 0.8667 3) 2 0.0 4) 1 0.0 5) 0 0.0 ------------------------------------------------------------ Obtained values ------------------------------------------------------------ Obtained Min Pixel Accuracy: 0.0% (max allowed=2%), Pass Obtained Average Pixel Accuracy: 0.0% (max allowed=1%), Pass Obtained Percentage of wrong values: 0.0% (max allowed=0%), Pass Obtained Pixel-wise L2 error: 0.0% (max allowed=1%), Pass Obtained Global Sum Difference: 0.0 ------------------------------------------------------------
Thank you, Let me check
