6592 Discussions
Release 2020.1 bug report - fusing replacer / Model Optimizer Tensorflow conversion error
Androsch__Horst
Hello !
OpenVINO version:   2020.1
MO command line:
python3 mo_tf.py --input_model /media/xavier/Modelle2020/mobilenetv2_deeplabv3/mobilev2deep.pb --input 0:MobilenetV2/Conv/Conv2D --input_shape [1,481,641,3] --output ResizeBilinear_2 --output_dir /media/xavier/Modelle2020/openvino/mobilenetv2_deeplabv3
.PB File: As .ZIP File attached
Error Output after mo-tf:
[ ERROR ]  Exception occurred during running replacer "fusing" (<class 'extensions.middle.fusings.Fusing'>): After partial shape inference were found shape collision for node Add2_ (old shape: [  1 241 321  32], new shape: [  1 241 321  -1])
Before 2020.1 I was using 2019.3 there the Outputfrom mo-tf was:
List of operations that cannot be converted to Inference Engine IR:
[ ERROR ]      FusedBatchNormV3 (59)
I got the Information that the FusedBatchNormV3 Problem would be saved in 2020.1 and so it was. But since 2020.1 there is the new "Add2_" Problem described above.
Please help if you can.
Greetings !
Max_L_Intel
Hello, Horst Androsch.
OpenVINO toolkit does not support FusedBatchNormV3 layer conversion. Please find the following topic for the workaround provided by one of users - https://software.intel.com/en-us/forums/intel-distribution-of-openvino-toolkit/topic/831459
Also, please take a look at this similar issue reported for ONNX model conversion - https://software.intel.com/en-us/forums/intel-distribution-of-openvino-toolkit/topic/832585
Hope this helps.
