6615 Discussions
Repository branches or commit IDs to be specified
Krishnendhu
I would like to know from the https://docs.openvinotoolkit.org/latest/openvino_docs_install_guides_installing_openvino_yocto.html
The instructions mentioned are
Set up Git repositories
The following Git repositories are required to build a Yocto image:
Clone these Git repositories to your host machine:
Set up BitBake* Layers
source poky/oe-init-build-env
bitbake-layers add-layer ../meta-intel
bitbake-layers add-layer ../meta-openembedded/meta-oe
bitbake-layers add-layer ../meta-openembedded/meta-python
bitbake-layers add-layer ../meta-clang
However the following downloads the latest and the greatest, it does not mention the branch or the commit ID which is verified. Please can someone help on this?
Munesh_Intel
Hi Krishnendu,
We are currently looking into this issue and will get back to you shortly.
Munesh
Munesh_Intel
Hi Krishnendu,
Thank you for waiting, and our apologies for the delay in replying to you.
We’ve checked with the developer team, and they’ve confirmed that the steps are correct. The latest and greatest branch (master branch) should work.
You should also be able to use dunfell LTS stable branch of all layers but that won't have the latest version of OpenVINO - it is at version 2020.1 and we have a policy of not upgrading OpenVINO version in stable branches.
Munesh
Munesh_Intel
Hi Krishnendu,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Munesh
