when I use mvNCCheck for my model, I got an error:
Traceback (most recent call last):
File "/usr/local/bin/mvNCCompile", line 169, in <module>
create_graph(args.network, args.image, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights, args.explicit_concat, args.ma2480, args.scheduler, args.new_parser, args)
File "/usr/local/bin/mvNCCompile", line 148, in create_graph
load_ret = load_network(args, parser, myriad_config)
File "/usr/local/bin/ncsdk/Controllers/Scheduler.py", line 103, in load_network
parse_ret = parse_caffe(arguments, myriad_conf)
File "/usr/local/bin/ncsdk/Controllers/CaffeParser.py", line 773, in parse_caffe
new_shape_X = layer.reshape_param.shape.dim[3]
IndexError: list index (3) out of range
so I look at /usr/local/bin/ncsdk/Controllers/CaffeParser.py , I found:
if isReshape(layer.type):
if(len(layer.reshape_param.shape.dim) == 3):
new_shape_X = 1
new_shape_Y = layer.reshape_param.shape.dim[2]
new_shape_C = layer.reshape_param.shape.dim[1]
else:
it seem the reshape layer's shape must be 3D or 4D, but one layer in my model is 2D, I want use reshape layer to reshape the 2D tensor to 1D tensor.
it's a bug? Is possible to reshape 2D to 1D? any help will be appreciate!
- Tags:
- Caffe
- Tensorflow
@shujunhua You can try using the flatten operation. See if this works for you. http://caffe.berkeleyvision.org/tutorial/layers/flatten.html
