Run pedestrian_tracker_demo error
Hung__Edwin
Hi:
I run pedestrian_tracker_demo error
has some error below
My version is latest version  "l_openvino_toolkit_p_2019.1.144"
$ ./pedestrian_tracker_demo -i /home/asrock/inference_engine_samples_build/intel64/persion-detection-retail-0013/PexelVideos1338590.mp4 -m_det /home/asrock/inference_engine_samples_build/intel64/persion-detection-retail-0013/person-detection-retail-0013.xml -d_det CPU -m_reid /home/asrock/inference_engine_samples_build/intel64/person-reidentification-retail-0031/person-reidentification-retail-0031.xml -d_reid CPU
InferenceEngine:
    API version ............ 1.6
    Build .................. custom_releases/2019/R1.1_28dfbfdd28954c4dfd2f94403dd8dfc1f411038b
[ INFO ] Parsing input parameters
Loading plugin CPU
    Build .................. 23780
    Description ....... MKLDNNPlugin
Segmentation fault (core dumped)
How should I do??
Thank you!
Michael_C_Intel1
Hi EdwinH,
Like the other posts, I'll move this one to computer vision forum from the OpenCL* forum to get more visibility from OpenVINO stakeholders.
You may want to post a stacktrace to the thread... The first thing I'd check for a seg fault for a program that many other users have executed successfully are the correctness of input arguments.
-MichaelC
Shubha_R_Intel
Dear Hung, Edwin,
I tried it on both GPU and CPU (OpenVino 2019R1.1), and it worked just fine.
Here is my command:
pedestrian_tracker_demo.exe -i c:\users\sdramani\Downloads\sample-videos\people-detection.mp4 -m_det c:\users\sdramani\Downloads\person-detection-retail-0013.xml -m_reid c:\users\sdramani\Downloads\person-reidentification-retail-0031.xml -d_det CPU -d_reid CPU
The only difference between yours and mine is that you're using a different video stream. Can you try it with the people-detection.mp4 from https://github.com/intel-iot-devkit/sample-videos  ? If you study the code (main.cpp) for the pedestrian_tracker_demo the video processing happens after plugin is loaded. I only get the following message once even though the plugin is called through -d_det and -d_reid twice :
Loading plugin CPU
And the next part is the video processing. So my guess is that this is where you core dump.
Can you give one of the sample videos a try ? Please report back here. To figure out why your video doesn't work would require stepping through the code. I'm pretty sure it's not a model issue - but likely the sample was not built to work with your video.
Shubha
Hung__Edwin
Thanks for help
I download the people-detection.mp4 and try again
The code can work!
Hung__Edwin
I also has question about the demo
Can the demo run on IP camera ??
Shubha_R_Intel
Dear Hung, Edwin,
IP Cameras are not optimal for the OpenVino samples. USB cameras work a lot better. It's possible but you may experience significant lagging and performance issues.
Please revisit IP Camera With OpenVino thread for the discussion.
Hope it helps,
Shubha
