Running Facenet Model using OpenVINO
Singh__Sanpreet
Hello to all,
Hope you are fine and will spare some time to direct me towards solution for problem encountered below.
I am struct at a problem in using OpenVINO. I am trying to run the facenet after converting model using OpenVINO toolkit but I am unable to use .npy and .pickle for complete face recognition. I am successful in converting .pb file to .bin and .xml file using OpenVino toolkit.
I hope, you would consider my problem and hint me towards the solution. I would be thankful to you.
With Regards
Sanpreet Singh (Python Developer)
Shubha_R_Intel
Sanpreet, I don't understand your issue ?  How are you trying to use .npy and .pickle ?  Please attach your code here as well as the error you are getting.
