6616 Discussions
Running gstreamer app in OpenVino using Windows subsystem in Linux (WSL2)
nnain1
My system main's OS is  Windows-10 OS and installed WSL2 in subsystem.
Openvino is installed in Linux under WSL2. The reason is dlstreamer-gst is supported only in linux.
When I test the following test app, it works only for fps and display is not working.
If I run app as
 ./vehicle_pedestrian_tracking.sh person-bicycle-car-detection.mp4 10 CPU fps
I can see the output as
FpsCounter(1sec): total=346.54 fps, number-streams=1, per-stream=346.54 fps
FPSCounter(average): total=340.06 fps, number-streams=1, per-stream=340.06 fps
Got EOS from element "pipeline0".
Execution ended after 0:00:02.456260800
Setting pipeline to NULL ...
Freeing pipeline ...
When I run for display,
./vehicle_pedestrian_tracking.sh person-bicycle-car-detection.mp4 10 CPU dispaly
I have error as
ERROR: from element /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstXvImageSink:xvimagesink0: Could not initialise Xv output
Additional debug info:
../sys/xvimage/xvimagesink.c(1778): gst_xv_image_sink_open (): /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstXvImageSink:xvimagesink0:
Could not open display (null)
ERROR: pipeline doesn't want to preroll.
Failed to set pipeline to PAUSED.
Is it display is not available in WSL subsystem?
nnain1
My solution is I can't display but I can save to file as
gst-launch-1.0 filesrc location=video1.avi ! decodebin ! video/x-raw ! queue ! gvadetect model=/home/nyan/intel/dl_streamer/models/intel/vehicle-detection/FP16/model_fp16.xml model-proc=./model_proc/vehicle-detection.json inference-interval=10 threshold=0.6 device=CPU ! queue ! gvafpscounter ! filesink location=output.avi
Wan_Intel
Hi Nnain1,
We are investigating this issue and will update you at the earliest.
Wan
Wan_Intel
Hi Nnain1,
I encountered the same error as you did when I tried to generate DISPLAY when executing vehicle_pedestrian_tracking.sh.
However, I can generate the DISPLAY when I use MobaXTerm with WSL2 and change the command of xvimagesink to ximagesink in vehicle_pedestrian_tracking.sh.
MobaXTerm is available for download on the following page:
https://mobaxterm.mobatek.net/download.html
Wan
Wan_Intel
Hi Nnain,
Based on the development team's response, the error you faced might be due to the x-server issue.
Hence, you can also change the command of xvimagesink to autovideosink in vehicle_pedestrian_tracking.sh
On another note, this thread will no longer be monitored since we have provided a solution.
If you need any additional information from Intel, please submit a new question.
Wan
