6605 Discussions
RuntimeError:Device with "FPGA" name is not registered in OpenVINO Runttime
STATEABC
I want to run the demo in open_model_zoo using FPGA AI Suite, but when I change the -d parameter to -d HETERO:FPGA,CPU, an error message appears when running the demo in the terminal:
RuntimeError:Device with "FPGA" name is not registered in OpenVINO Runttime.
Any help would be greatly appreciated, thank you!
Wan_Intel
Hi STATEABC,
May I know which version of OpenVINO™ toolkit are you using on your machine? For your information, the FPGA plugin is not a supported plugin for the latest version of OpenVINO™ toolkit. You may refer to the following link for more information.
https://docs.openvino.ai/2024/about-openvino/compatibility-and-support/supported-devices.html
Wan
Wan_Intel
Hi STATEABC,
We noticed that you've posted a related question at the following thread:
https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/Failure-due-to-generic-standard-exception-gt-isa-lt-gt-used-on-a/m-p/1615721
For your information, we will close this case and continue to support you at the thread above.
Wan
