Segmentation fail on Raspberry Pi 3
I am new to Movidius NCS.
As I followed the steps of this website ( https://goo.gl/kxC1L6) to build the Graph file from Keras, I encountered the segmentation failure when running inference on Raspberry Pi 3. Can anyone help me with the problem? Thank you.
I used NCSDK2 to compile the model.
The following are the files that I used to build and run for the NCS inference.
  1. Generating Keras Model:
    http://oz.nthu.edu.tw/~g9512535/problem/generate_model.py
  2.
  3. Peel of the Keras shell and convert to Tensorflow model:
    http://oz.nthu.edu.tw/~g9512535/problem/peel_off_keras.py
  4.
  5. Load data from MNIST data set for inference test:
    http://oz.nthu.edu.tw/~g9512535/problem/convert_to_numpy_array.py
  6.
  7. Inference the number:
    http://oz.nthu.edu.tw/~g9512535/problem/ncs_inference.py
  8.
