6584 Discussions
Sizes equal or broadcast is possible(true) should be false. Invalid input shapes
Kizna1ver
I am following the sample
Direct Consuming of the NV12 VAAPI Video Decoder Surface on Linux
and try to build a model on the va device used in ffmpeg hardware decoder. But I encounted some error below when calling the function compile_model().
My system infomation:
  • OpenVINO=> 2022.1
  • Operating System / Platform => ubuntu20.04
Part of my codes:
    size_t input_height = 300;
    size_t input_width = 300;
    // initialize the core and load the network
    ov::Core core;
    auto model = core.read_model("/opt/intel/openvino_2022.1.0.643/samples/cpp/hello_remote_blob/public/ssd300/FP32/ssd300.xml");
    printf("Preprocessing...\n");
    auto p = PrePostProcessor(model);
    p.input().tensor().set_element_type(ov::element::u8)
                    .set_color_format(ov::preprocess::ColorFormat::NV12_TWO_PLANES, {"y", "uv"})
                    .set_memory_type(ov::intel_gpu::memory_type::surface);
    p.input().preprocess()
                    .convert_color(ov::preprocess::ColorFormat::BGR);
    p.input().model().set_layout("NCHW");
    model = p.build();
    printf("Build finished\n");
    // create the shared context object
    auto shared_va_context = ov::intel_gpu::ocl::VAContext(core, display);
    // compile model within a shared context
    auto compiled_model = core.compile_model(model, shared_va_context);
    printf("Compile model finished\n");
 The error:
 terminate called after throwing an instance of 'ov::Exception'
what(): Error has occured for: add:data/mean
 part of ssd300.xml file(This file is obtained by omz_downloader and omz_converter):
<layer id="0" name="data" type="Parameter" version="opset1">
			<data shape="1,3,300,300" element_type="f32"/>
			<rt_info>
				<attribute name="fused_names" version="0" value="data"/>
			</rt_info>
			<output>
				<port id="0" precision="FP32" names="data">
					<dim>1</dim>
					<dim>3</dim>
					<dim>300</dim>
					<dim>300</dim>
					<rt_info>
						<attribute name="layout" version="0" layout="[N,C,H,W]"/>
					</rt_info>
				</port>
			</output>
		</layer>
		<layer id="1" name="data/mean_input_port_1/value8827915" type="Const" version="opset1">
			<data element_type="f32" shape="1, 3, 1, 1" offset="0" size="12"/>
			<rt_info>
				<attribute name="fused_names" version="0" value="data/mean_input_port_1/value8827915"/>
			</rt_info>
			<output>
				<port id="0" precision="FP32">
					<dim>1</dim>
					<dim>3</dim>
					<dim>1</dim>
					<dim>1</dim>
				</port>
			</output>
		</layer>
		<layer id="2" name="data/mean" type="Add" version="opset1">
			<data auto_broadcast="numpy"/>
			<rt_info>
				<attribute name="fused_names" version="0" value="data/mean"/>
			</rt_info>
			<input>
					<dim>1</dim>
					<dim>3</dim>
					<dim>300</dim>
					<dim>300</dim>
				</port>
				<port id="1" precision="FP32">
					<dim>1</dim>
					<dim>3</dim>
					<dim>1</dim>
					<dim>1</dim>
				</port>
			</input>
			<output>
				<port id="2" precision="FP32">
					<dim>1</dim>
					<dim>3</dim>
					<dim>300</dim>
					<dim>300</dim>
				</port>
			</output>
		</layer>
The XML file seems to correct, I don't know why this error is raised. And my complete code in this repository.
Thanks!
Peh_Intel
Hi Kizna1ver,
Sorry for my late response as I still facing challenges in installing FFMPEG with VAAPI support. By the way, it is glad to hear that the error was resolved as per this GitHub discussion.
As for the C API of RemoteBlob, there is no plan yet from our development.
Sincerely,
Peh
Peh_Intel
Hi Kizna1ver,
By adding the pre-processing step of converting to ‘float’, did the error resolved?
           .convert_element_type(ov::element::f32)
Peh
Kizna1ver
Hi Peh_Intel,
Thanks for reply,
After modified, my code is
But the error still occurs:
  what():  cldnn program build failed! Error has occured for: convert:Convert_826
No image_nv12 to image_nv12 reorder is supported
Aborted (core dumped)
Peh_Intel
Hi Kizna1ver,
I was not able to reproduce the issue because fail to build the application based on your repository.
Can you share the config.h file that included in the main.cpp?
Peh
Kizna1ver
Hi Peh_Intel,
Thanks for reply,
I push the config.h file to the repository. If you need to build this project, you need to install FFMPEG with VAAPI support first. And I added the complement information in the readme.md file. Thanks!
Peh_Intel
Hi Kizna1ver,
Thanks for the updates in building the project.
We are still investigating this issue and will get back to you at the earliest.
Peh
Kizna1ver
Hi Peh_Intel,
Thanks for reply and helping me solve this issue
By the way, does openvino community plan to develop C API of RemoteBlob?
Peh_Intel
Hi Kizna1ver,
Sincerely,
Peh
Peh_Intel
Hi Kizna1ver,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Peh
