6605 Discussions
Specify CPU extension in version 2021.1.110 ?
jobdulo
I am following the instructions at https://github.com/intel-iot-devkit/smart-retail-analytics on how to run the smart retail analytics app. Everything is okay until running Grafana on the browser. On the terminal I am getting the following output and error;
[ ERROR ] Please try to specify cpu extensions library path in command line parameters using -l or --cpu_extension command line argument
I assumed that the CPU extension did not need specification on OpenVINO versions > 2019.
I am using the 2021.1.110 version on WSL Ubuntu Ubuntu 20.04.1 LTS.
What I have tried
I have tried looking for any cpu extension in /opt/intel/openvino_2021.1.110/deployment_tools/inference_engine/lib/intel64 but there is none.
Any help?
jobdulo
so finally, I decided to change my system and retried the whole set up. I used the following specifications (different from the initial ones);
WSL Ubuntu 18.04
Intel(R) OpenVINO Toolkit version 2020.3.341
Python 3.6.9
And now everything works perfectly.
Adli
Hi jobdulo,
Thank you for reaching out to us. Did you get any errors besides the 'specify CPU extensions' error? If possible, could you share the full log error here?
Please share the additional information regarding:
• CPU processor
• Python version
Adli
jobdulo
This is the complete log:
[ INFO ] Initializing plugin for CPU device...
[ INFO ] Reading IR...
[ INFO ] Loading IR to the plugin...
/home/cv_admin/smart-retail-analytics/application/inference.py:85: DeprecationWarning: 'layers' property of IENetwork class is deprecated. For iteration over network please use get_ops()/get_ordered_ops() methods from nGraph Python API
[l for l in self.net.layers.keys() if l not in supported_layers]
/home/cv_admin/smart-retail-analytics/application/inference.py:102: DeprecationWarning: 'inputs' property of IENetwork class is deprecated. To access DataPtrs user need to use 'input_data' property of InputInfoPtr objects which can be accessed by 'input_info' property.
self.input_blob = next(iter(self.net.inputs))
[ ERROR ] Following layers are not supported by the plugin for specified device CPU:
Constant_14990, Constant_14988
Here are the system details;
Python version 3.8.5
Intel(R) Core i7-1065G7 CPU
jobdulo
WSL Ubuntu 18.04
Python 3.6.9
Adli
Hi jobdulo,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Adli
jobdulo
Thank you for the help!
