6578 Discussions
Stick does not respond on Ubuntu 16.04 x64 machine
root@Laptop:/opt/demo/ncsdk# dmesg
[19001.766610] usb 8-1: USB disconnect, device number 3
[19005.925146] usb 8-2: new high-speed USB device number 4 using xhci_hcd
[19006.079141] usb 8-2: New USB device found, idVendor=03e7, idProduct=2485
[19006.079149] usb 8-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[19006.079153] usb 8-2: Product: Movidius MyriadX
[19006.079156] usb 8-2: Manufacturer: Movidius Ltd.
[19006.079158] usb 8-2: SerialNumber: 03e72485
Network Input tensors ['data#24']
Network Output tensors ['prob#38']
Blob generated
W: [ 0] ncDeviceOpen:528 ncDeviceOpen() XLinkBootRemote returned error 3
[Error 7] Toolkit Error: USB Failure. Code: Error opening device
Makefile:64: recipe for target 'profile' failed
make[3]: *** [profile] Error 255
make[3]: Leaving directory '/opt/demo/ncsdk/examples/caffe/AlexNet'
Makefile:12: recipe for target 'AlexNet' failed
make[2]: *** [AlexNet] Error 2
make[2]: Leaving directory '/opt/demo/ncsdk/examples/caffe'
Makefile:12: recipe for target 'caffe/.' failed
make[1]: *** [caffe/.] Error 2
make[1]: Leaving directory '/opt/demo/ncsdk/examples'
Makefile:57: recipe for target 'examples' failed
make: *** [examples] Error 2
root@Laptop:/opt/demo/ncsdk# lsusb
Bus 005 Device 002: ID 138a:003d Validity Sensors, Inc. VFS491
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 004: ID 1bcf:2c03 Sunplus Innovation Technology Inc.
Bus 001 Device 003: ID abcd:1234 Unknown
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 0a5c:21e1 Broadcom Corp. HP Portable SoftSailing
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 009 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 008 Device 004: ID 03e7:2485
Bus 008 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 006 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Hi @tspann
It looks like you have an Intel Neural Compute Stick 2, you will need to use the OpenVINO toolkit as the NCS2 is not supported on the ncsdk.
Take a look at the getting started page: https://software.intel.com/en-us/neural-compute-stick/get-started
You can post any OpenVINO questions on the OpenVINO forum: https://software.intel.com/en-us/forums/computer-vision
Hope this helps!
Jesus
