Summarize Openvino R3
Mspiz
trying summarize_graph inside Openvino R3 I have this behavior:
python  mo/utils/summarize_graph.py --input_model=model.pb
  File "mo/utils/summarize_graph.py", line 12
    def children(op_name: str, graph: tf.Graph):
SyntaxError: invalid syntax
It is know issue?
Cheers,
Carmine
Monique_J_Intel
Hi Carmine,
This is not a known issue. However, I was able to reproduce your issue. I ran this command with python 2.7.12
python summarize_graph.py --input_model ~/Desktop/firstcnn/myfirstgraphdef/myfirstcnn.pb
and received your error and then I ran the command with Python 3.5.2
python3 summarize_graph.py --input_model ~/Desktop/firstcnn/myfirstgraphdef/myfirstcnn.pb
and the summarize graph showed the inputs and outputs. Let me know if this helps at all?
Kind Regards,
Monique Jones
Mspiz
Thanks, let you know as soon as possible.
Cheers,
Carmine Spizuoco
