Super resolution on 16 bit images
Effe
Hi!
im using single-image-super-resolution-1032.
Is it possible to use it on 16bit or 32bit images?
Peh_Intel
Hi Effe,
Based on the single-image-super-resolution-1032 documentation (An Attention-Based Approach for Single Image Super Resolution), the model is trained by using images from the DIV2K dataset. It consists of 1000 diverse 2K resolution RGB images.
Furthermore, this model can be executed with Image Processing C++ Demo with JPEG image format but JPEG only supports 8-bit images.
Peh
Peh_Intel
Hi Effe,
This thread will no longer be monitored since we have provided answer. If you need any additional information from Intel, please submit a new question.
Peh
