Support for Deconvolution
Hi all,
I am trying to make a simple network to learn the identity function, i.e., take an input image and give back the same image.
I am using the CIFAR10 dataset for training.
My architecture is as follows:
Input (32 x 32 x 3) -> Conv (8 filters, 5x5 filter size and 2,2 strides with same padding and ReLU activation) -> ConvTranspose (3 filters, 5x5 filter size and 2,2 strides with same padding and no activation).
I get the following error when I try to compile:
/usr/local/bin/ncsdk/Controllers/Parsers/TensorFlowParser/Convolution.py:46: SyntaxWarning: assertion is always true, perhaps remove parentheses? assert(False, "Layer type not supported by Convolution: " + obj.type) /usr/local/bin/ncsdk/Controllers/Parsers/Phases.py:322: SyntaxWarning: assertion is always true, perhaps remove parentheses? assert(len(pred) == 1, "Slice not supported to have >1 predecessors") mvNCCompile v02.00, Copyright @ Intel Corporation 2017 ****** Info: No Weights provided. inferred path: inference.data-00000-of-00001****** shape: (1, 32, 32, 3) [Error 5] Toolkit Error: Stage Details Not Supported: Wrong deconvolution output shape.
Any help will be greatly appreciated.
Here are my model files.
The command I am running is as follows:
mvNCCompile inference.meta -s 12 -in Input -on deconv1T/BiasAdd -o inference.graph
Using NCS API v2 fixed this issue.
