Tensorflow error
chaudhuri__subhendu
When trying to import tensorflow it is giving this error
C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\install_prerequisites>python
Python 3.6.5 (v3.6.5:f59c0932b4, Mar 28 2018, 17:00:18) [MSC v.1900 64 bit (AMD64)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> import numpy
>>> import cv2
>>> import tensorflow as tf
Traceback (most recent call last):
  File "C:\Users\Subhendu\AppData\Roaming\Python\Python36\site-packages\tensorflow_core\python\pywrap_tensorflow.py", line 58, in <module>
    from tensorflow.python.pywrap_tensorflow_internal import *
  File "C:\Users\Subhendu\AppData\Roaming\Python\Python36\site-packages\tensorflow_core\python\pywrap_tensorflow_internal.py", line 28, in <module>
    _pywrap_tensorflow_internal = swig_import_helper()
  File "C:\Users\Subhendu\AppData\Roaming\Python\Python36\site-packages\tensorflow_core\python\pywrap_tensorflow_internal.py", line 24, in swig_import_helper
    _mod = imp.load_module('_pywrap_tensorflow_internal', fp, pathname, description)
  File "C:\Program Files\Python36\lib\imp.py", line 243, in load_module
    return load_dynamic(name, filename, file)
  File "C:\Program Files\Python36\lib\imp.py", line 343, in load_dynamic
    return _load(spec)
ImportError: DLL load failed: A dynamic link library (DLL) initialization routine failed.
During handling of the above exception, another exception occurred:
  File "<stdin>", line 1, in <module>
  File "C:\Users\Subhendu\AppData\Roaming\Python\Python36\site-packages\tensorflow\__init__.py", line 99, in <module>
    from tensorflow_core import *
  File "C:\Users\Subhendu\AppData\Roaming\Python\Python36\site-packages\tensorflow_core\__init__.py", line 28, in <module>
    from tensorflow.python import pywrap_tensorflow  # pylint: disable=unused-import
  File "C:\Users\Subhendu\AppData\Roaming\Python\Python36\site-packages\tensorflow\__init__.py", line 50, in __getattr__
    module = self._load()
  File "C:\Users\Subhendu\AppData\Roaming\Python\Python36\site-packages\tensorflow\__init__.py", line 44, in _load
    module = _importlib.import_module(self.__name__)
  File "C:\Program Files\Python36\lib\importlib\__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "C:\Users\Subhendu\AppData\Roaming\Python\Python36\site-packages\tensorflow_core\python\__init__.py", line 49, in <module>
  File "C:\Users\Subhendu\AppData\Roaming\Python\Python36\site-packages\tensorflow_core\python\pywrap_tensorflow.py", line 74, in <module>
    raise ImportError(msg)
ImportError: Traceback (most recent call last):
    return _load(spec)
Failed to load the native TensorFlow runtime.
See https://www.tensorflow.org/install/errors
for some common reasons and solutions.  Include the entire stack trace
above this error message when asking for help.
Please Help
JesusE_Intel
Hi chaudhuri, subhendu,
OpenVINO will install Tensorflow and OpenCV during setup. You can check the version of Tensorflow with pip show tensorflow. Also, make sure to source the environment variables.
C:\Program Files (x86)\IntelSWTools\openvino\bin\setupvars.bat
Jesus
JesusE_Intel
Which version of the OpenVINO toolkit are you using? Did you have Tensorflow installed prior to installing OpenVINO? Please check to make sure that you are using Tensorflow version 1.14.0.
Jesus
chaudhuri__subhendu
Dear Jesus
How will I  control the version of tensorflow within openvino?
Will I install tensflow and OpenCV separately?
JesusE_Intel
Jesus
