6616 Discussions
Tensorflow model exporter error - Cannot infer shapes or values for node "image_padding/Ceil_1"
Moosa__Azmath
I am trying to export a frozen inference graph pb file.  It is a custom bbox detection network with inception v1 blocks.  While running the model optimizer, I am getting some errors.  The graph was trained and exported from tf v1.10.  I want to know how I  can debug this model and get it exported.
The command line I used
/opt/intel/openvino/deployment_tools/model_optimizer/mo_tf.py --input_model /data/work/face-rec/face-rec/src/assets/faceboxes-model.pb --input_shape "(1,1024,1024,3)" --input image_tensor  --output_dir ./ --log_level=DEBUG
The error that I am getting is as follows:
[ 2020-04-22 10:52:33,606 ] [ DEBUG ] [ infer:128 ]  --------------------
[ 2020-04-22 10:52:33,606 ] [ DEBUG ] [ infer:129 ]  Partial infer for image_padding/Ceil_1
[ 2020-04-22 10:52:33,606 ] [ DEBUG ] [ infer:130 ]  Op: Ceil
[ 2020-04-22 10:52:33,606 ] [ DEBUG ] [ infer:131 ]  Inputs:
[ 2020-04-22 10:52:33,606 ] [ DEBUG ] [ infer:31 ]  input[0]: shape = [], value = 8.0
[ INFO ]  Called "tf_native_tf_node_infer" for node "image_padding/Ceil_1"
[ 2020-04-22 10:52:33,607 ] [ DEBUG ] [ tf:226 ]  Added placeholder with name 'image_padding/truediv_1_port_0_ie_placeholder'
[ 2020-04-22 10:52:33,607 ] [ DEBUG ] [ tf:239 ]  update_input_in_pbs: replace input 'image_padding/truediv_1' with input 'image_padding/truediv_1_port_0_ie_placeholder'
[ 2020-04-22 10:52:33,607 ] [ DEBUG ] [ tf:247 ]  Replacing input '0' of the node 'image_padding/Ceil_1' with placeholder 'image_padding/truediv_1_port_0_ie_placeholder'
[ ERROR ]  Cannot infer shapes or values for node "image_padding/Ceil_1".
[ ERROR ]  Input 0 of node image_padding/Ceil_1 was passed float from image_padding/truediv_1_port_0_ie_placeholder:0 incompatible with expected double.
[ ERROR ]
[ ERROR ]  It can happen due to bug in custom shape infer function <function tf_native_tf_node_infer at 0x7f4cceef7378>.
[ ERROR ]  Or because the node inputs have incorrect values/shapes.
[ ERROR ]  Or because input shapes are incorrect (embedded to the model or passed via --input_shape).
[ 2020-04-22 10:52:33,759 ] [ DEBUG ] [ infer:196 ]  Node "image_padding/Ceil_1" attributes: {'pb': name: "image_padding/Ceil_1"
op: "Ceil"
input: "image_padding/truediv_1_port_0_ie_placeholder"
attr {
  key: "T"
  value {
    type: DT_DOUBLE
, '_in_ports': {0: {'control_flow': False}}, '_out_ports': {0: {'control_flow': False}}, 'kind': 'op', 'name': 'image_padding/Ceil_1', 'op': 'Ceil', 'infer': <function tf_native_tf_node_infer at 0x7f4cceef7378>, 'is_output_reachable': True, 'is_undead': False, 'is_const_producer': False, 'is_partial_inferred': False}
[ ERROR ]  Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.middle.PartialInfer.PartialInfer'>): Stopped shape/value propagation at "image_padding/Ceil_1" node.
 For more information please refer to Model Optimizer FAQ (https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_Model_Optimizer_FAQ.html), question #38.
[ 2020-04-22 10:52:33,761 ] [ DEBUG ] [ main:317 ]  Traceback (most recent call last):
  File "/home/azmath/anaconda3/lib/python3.7/site-packages/tensorflow/python/framework/importer.py", line 426, in import_graph_def
    graph._c_graph, serialized, options)  # pylint: disable=protected-access
tensorflow.python.framework.errors_impl.InvalidArgumentError: Input 0 of node image_padding/Ceil_1 was passed float from image_padding/truediv_1_port_0_ie_placeholder:0 incompatible with expected double.
I think I need to override the DT_DOUBLE to Float.  Could anyone guide me on how I can do that?
SuryaPSC_Intel
Hi Azmath,
Can you please confirm if the model is one of the supported topologies of tensorflow. For face detection problem kindly refer to Interactive face detection demo.
Surya
ashna_12
Is this issue solved? If yes, how did you solve this?
I'm also facing a similar kind of issue.
