Tensorflow mvnNCCheck error
OS: Ubuntu 16.04 LTS, Anaconda Python 2.7
I am executing the commands as
~/workspace/ncsdk/examples/tensorflow/inception_v1$ make compile
~/workspace/ncsdk/examples/tensorflow/inception_v1$ make weights
~/workspace/ncsdk/examples/tensorflow/inception_v1$ make check
and then I get these errors.
test -f output/inception-v1.meta || ((wget http://download.tensorflow.org/models/inception_v1_2016_08_28.tar.gz && tar zxf inception_v1_2016_08_28.tar.gz && rm inception_v1_2016_08_28.tar.gz) && ./inception-v1.py)
mvNCCheck -s 12 output/inception-v1.meta -in=input -on=InceptionV1/Logits/Predictions/Reshape_1 -i ../../data/images/cat.jpg -id 829 -S 2 -M 128 -cs 0,1,2
mvNCCheck v02.00, Copyright @ Movidius Ltd 2016
/usr/local/lib/python3.5/dist-packages/tensorflow/python/util/tf_inspect.py:45: DeprecationWarning: inspect.getargspec() is deprecated, use inspect.signature() instead
if d.decorator_argspec is not None), _inspect.getargspec(target))
Traceback (most recent call last):
File "/usr/local/bin/mvNCCheck", line 144, in
quit_code = check_net(args.network, args.image, args.inputnode, args.outputnode, args.nshaves, args.inputsize, args.weights, args)
File "/usr/local/bin/mvNCCheck", line 122, in check_net
net = parse_tensor(args, myriad_config, file_gen=True)
File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 229, in parse_tensor
channel_swap=arguments.channel_swap)
File "/usr/local/bin/ncsdk/Controllers/MiscIO.py", line 231, in parse_img
import skimage.transform
File "/usr/local/lib/python3.5/dist-packages/skimage/transform/init.py", line 1, in
from .hough_transform import (hough_line, hough_line_peaks,
File "/usr/local/lib/python3.5/dist-packages/skimage/transform/hough_transform.py", line 3, in
from .. import measure
File "/usr/local/lib/python3.5/dist-packages/skimage/measure/init.py", line 6, in
from ._regionprops import regionprops, perimeter
File "/usr/local/lib/python3.5/dist-packages/skimage/measure/_regionprops.py", line 7, in
from ._label import label
File "/usr/local/lib/python3.5/dist-packages/skimage/measure/_label.py", line 1, in
from ._ccomp import label_cython as clabel
ImportError: cannot import name 'label_cython'
Makefile:55: recipe for target 'check' failed
make: [check] Error 1 (ignored)
@sambhu We are aware of a compatibility issue with Anaconda and the NCSDK. Please try using a computer/environment without Anaconda. Let me know if this works for you. Thanks.
@Tome_at_Intel i am using a computer without Anaconda but there have same problem mvNCCheck error.please tell me others solution.
I get the same problem for ubuntu16.04
@sambhu @TheOnlyWing Can you try the command "make run" and paste the output here?
