Text Detection C++ Demo show no image
ininder__gg
hi sir.
I'm trying new 2019 version Openvino's Text Detection C++ demo. after some test, it works fine and outputs something like :
text detection model inference (ms) (fps): 655 1.52672
text detection postprocessing (ms) (fps): 141 7.0922
text recognition model inference (ms) (fps): 26.76 37.3692
text recognition postprocessing (ms) (fps): 0.0261467 38245.8
text crop (ms) (fps): 0.0584533 17107.7
However, it doesn't show any imshow window no matter how the -no_show tag is set or not set. Also, the -i tag cannot find a video file or camera.
what I have tried:
./text_detection_demo -i /dev/video0 -m_td ~/textmodel/text-detection-0002.xml -m_tr ~/textmodel/text-recognition-0012.xml -no_show 1
 and return
Could not read an image: /dev/video0
./text_detection_demo -i ~/a.png -m_td ~/textmodel/text-detection-0002.xml -m_tr ~/textmodel/text-recognition-0012.xml -no_show 0
works but no image show
./text_detection_demo -i ~/a.png -m_td ~/textmodel/text-detection-0002.xml -m_tr ~/textmodel/text-recognition-0012.xml -no_show 1
works but no image shows ,neither
and if I want to read video file
./text_detection_demo -m_td ~/textmodel/text-detection-0002.xml -m_tr ~/textmodel/text-recognition-0012.xml -i ~/a.avi
and return
Could not read an image: /home/gino/a.avi
what should I do?
Shubha_R_Intel
Dear ininder, gg,
I'm assuming that you obtained your models from :
https://download.01.org/opencv/2019/open_model_zoo/R1/models_bin/
Correct  ? I am looking at this issue for you. Thanks for your patience,
Shubha
Shubha_R_Intel
Dearest ininder, gg,
This is a bug. Thanks for finding it. I have reproduced your issues ! I will file a bug on your behalf,
Sincerely,
Shubha
nikos1
Valued Contributor I
Hello ininder, gg,
How are you getting the text recognition results?
My understanding is you need a CTC decoder. I think there is an Intel OpenCL version of a greedy CTC decoder and possibly a CPU version too.
Have not checked the sample yet... maybe already using the CTC decoder?
Cheers,
nikos
nikos1
Never mind I can see the CTCGreedyDecoder is already in the sample. Works nicely!
nikos1
What happens if you try
./text_detection_demo -i video.mp4 -m_td text-detection-0002.xml -m_tr text-recognition-0012.xml -dt video
Works fine here processing the input video and drawing text regions and OCR results
Cheers,
Nikos
Shubha_R_Intel
nikos, thanks ! yes -dt video solved the problem. Still a bug though, because it should be clear in the documentation. it's not !
Thanks for helping out,
Shubha
ininder__gg
ok, it works fine.
thank you, sir.
ininder__gg
after taking a while look in text detection example,
I try CPU + MYRIAD ( I have only 1 NCS stick )
when using MYRIAD to detect, CPU to recognize they work fine as using CPU in both tasks, however
, if using CPU to detect, MYRIAD to recognize, it would find nothing and no text to be outputed.
I think it's the way the neural compute stick works.
