6605 Discussions
The VX function vxQueryGraph() does not seem to work well.
Peng_X_
When I use the VX function
vxQueryGraph(graph, VX_GRAPH_PERFORMANCE, &perf, sizeof(perf));
to get the performance of a graph, the result seems to be wrong. Is this because the Intel implementation doesn't use this function? Maybe  I should write my own function to get the performance?
Peng_X_
The problem has been solved. Unlike the implementation of AMD, Intel CV SDK disables the performance measurement by default (maybe to save a bit of time?). So we need to use
vxDirective((vx_reference)context, VX_DIRECTIVE_ENABLE_PERFORMANCE);
to enable the measurement first. (If you want to measure the performance of a graph, you should use it before the execution of the graph. It you want  to measure the performance of a node, you'd better use it before you add the node to the graph.)
Jeffrey_M_Intel1
Glad you've found a solution.  By the way, VAD also has an increasing amount of features for measuring graph performance and trying performance experiments for optimization.
