6594 Discussions
The problem with export tensorflow model of fp16
kang__alex
Expected Behavior
      It is work on GPU or Movidius with FP16 Model
Current Behavior
    The result text display erro
Steps to Reproduce (for bugs)
     export the FP16 model
    get the bin and xml file
    put the file to the correct place.
Context
I can not get the right result .
My Environment
OS Platform and Distribution (e.g., Linux Ubuntu 16.04):ubuntu 16.04
TensorFlow installed from (source or binary):binary
TensorFlow version (use command below):1.10.0
python -c "import tensorflow as tf; print(tf.GIT_VERSION, tf.VERSION)"
Python version:3.5
CUDA/cuDNN version:9.0 7
GPU model and memory:
The model can worked on CPU with export FP32,but can not worked on MYRiad
Is anybody could help me。
Shubha_R_Intel
Dear kang, alex,
Whether a model fully works or not on GPU or Myriad, while it works perfectly fine on CPU, fully depends on whether the layers of the model are also supported on GPU or Myriad.
Please review the Supported Devices list to see if all your model's layers are supported (or not) for GPU and Myriad.
Hope it helps,
Thanks !
Shubha
Hou_y_1
Shubha R. (Intel) wrote:
Dear kang, alex,
Hope it helps,
Thanks !
Shubha
Hi, Axpy Layer( caffe) is supported with fp16 on gpu?  I tested a caffemodel with Axpy layer, but a part of feature is null. I tested the same data with the other model without Axpy, I get right results.
kang__alex
Thank you for your reply, i followed this link https://github.com/opencv/openvino_training_extensions/blob/develop/tensorflow_toolkit/lpr/README.md , training and export model,
but the fp32 model worked, and fp16 model cannot work. is there any special config for mo.py (eg. scale value, mean_value ) should be set for the export, I can not find any config in this link https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_convert_model_Convert_Model_From_TensorFlow.html
and when I use cross_check tools for those models(fp32 fp16),it said “ unsupported primitive of type: ctcgreedydecoder name :ctcgreedydecoder” ,could you tell me what should I do?
Dear kang, alex,
Hope it helps,
Thanks !
Shubha
kang__alex
Hi,I tested a tensorflow with fp16 on gpu?I think there is not the Axpy Layer in my model。
Hou y. wrote:
Dear kang, alex,
Hope it helps,
Thanks !
Shubha
Shubha_R_Intel
Dear kang, alex,
you are correct. Axpy Layer is not supported. However you can add it by making a custom layer.  Here's a kinda old Custom Layer IDZ Post on how to do that but the content is still relevant. Redirect to the 2019 part of the repo for the references.
Also take a look at the below documentation:
https://docs.openvinotoolkit.org/latest/_docs_IE_DG_Integrate_your_kernels_into_IE.html
Hope it helps.
Thanks !
Shubha
kang__alex
Thank you for your reply, but there is not Axpy Layer in my modle, the error message said CTCGreedydecoder is not supported, but  I found this layer is supported on this link http://docs.openvinotoolkit.org/latest/_docs_IE_DG_supported_plugins_Supported_Devices.html
but when I use cross_check tools for those models(fp32 and fp16),it said “ unsupported primitive of type: ctcgreedydecoder name :ctcgreedydecoder” ,could you tell me what should I do?
Thanks !
Alex
Dear kang, alex,
Hope it helps.
Thanks !
Shubha
Shubha_R_Intel
Dear kang, alex, instead of cross_check_tool.py can you tell me what benchmark_app does ? There's a Python and C++ version. Please try it and report the results here. And you are correct,  CTCGreedydecoder is definitely supported.
Shubha
kang__alex
Dear Shubha R.
       The benchmar_app log  message is :
Progress: [....................] 100.00% done
[Step 8/8] Dump statistics report
[ INFO ] Statistics collecting was not requested. No reports are dumped.
and the attachment is my model an xml file .could you help me to check it ?
Shubha
