6584 Discussions
TopK error from onnx model misses "k" attribute
Chen__Boyuan
File "/opt/intel/openvino_2019.3.376/deployment_tools/model_optimizer/extensions/front/TopKNormalize.py", line 38, in find_and_replace_pattern
    assert topk_node.has_valid('k'), 'The TopK node "{}" misses "k" attribute'.format(topk_node.name)
AssertionError: The TopK node "TopK_101" misses "k" attribute
Some debug gives me:
1. 'k' is not in self.graph.node["TopK_101"].keys()
2. However, 'k' is present in the attribute of self.graph.node["TopK_101"].['pb']
input: "253"
output: "254"
output: "255"
op_type: "TopK"
attribute {
  i: 3
  type: INT
attribute {
  i: 100
  type: INT
SIRIGIRI_V_Intel
Can you please answer the below questions:
  1. What is the topology of the model
  2. Is the model a public model or custom model
  3. What is the model optimizer command you have used to convert the model
We recommend to use the latest version of OpenVINO(2020.2). Could you please give a try and let us know the results.
Ram prasad
