OpenVINO version : openvino_2022.1.0.643
OS : Windows Version 10.0.19044 Build 19044
I want to use the OpenVINO runtime engine in a C++ application which is configured for Visual Studio 2017. The problem is that OpenVINO 2022.1 (the latest version) is only configured for Visual Studio 2019.
I still tried to build using 2022.1 but I obviously get errors which are similar to those :
E1696 Cannot open source file "ie_plugin_config.hpp" C:\Program Files (x86)\Intel\openvino_2022\runtime\include\openvino\runtime\core.hpp 18
E1696 Cannot open source file "ie_precision.hpp" C:\Program Files (x86)\Intel\openvino_2022\runtime\include\openvino\runtime\properties.hpp 19
E0145 Cannot initalize member "ov::AttributeVisitor::invalid_node_id" C:\Program Files (x86)\Intel\openvino_2022\runtime\include\openvino\core\attribute_visitor.hpp 120
E0145 Cannot initalize member "ov::Interval::s_max" C:\Program Files (x86)\Intel\openvino_2022\runtime\include\openvino\core\interval.hpp 109
E0145 Cannot initalize member "ov::float16::frac_size" C:\Program Files (x86)\Intel\openvino_2022\runtime\include\openvino\core\type\float16.hpp 23
E0145 Cannot initalize member "ov::float16::exp_size" C:\Program Files (x86)\Intel\openvino_2022\runtime\include\openvino\core\type\float16.hpp 24
E0145 Cannot initalize member "ov::float16::exp_bias" C:\Program Files (x86)\Intel\openvino_2022\runtime\include\openvino\core\type\float16.hpp 25
C1083 Cannot open include file: 'ie_plugin_config.hpp': No such file or directory (compilation of source file ../../source_file.cpp) c:\program files (x86)\intel\openvino_2022\runtime\include\openvino\runtime\core.hpp 18
I have already used OpenVINO runtime in a very simple C++ application to check if my installation works, this time using Visual Studio 2019. Everything works fine.
First thing to say is that upgrading the initial C++ application to a Visual Studio 2019 project cannot be done.
So I tried to find a version of OpenVINO that works for Visual Studio 2017. I found out that OpenVINO 2019_R1 works on Visual Studio 2017 (https://github.com/openvinotoolkit/openvino/tree/2019_R1/inference-engine), but the installer isn't available anymore on Intel's website (https://www.intel.com/content/www/us/en/developer/tools/openvino-toolkit/download-previous-versions.html?operatingsystem=window&distributions=webdownload&version=2019%20Update%201%20Eng/Jpn&options=online)
So I tried to build from source, cloning the 2019_R1 tag from github and following the build instructions, but the project needs Intel C++ Compiler 18.0 which can't be found anymore.
My questions are :
- Is there a easier way to make OpenVINO Runtime work for Visual Studio 2017 ?
- If not, is there a way to get access to a 2019_R1 version of OpenVINO ?
- Is the Inference Engine the same thing as Runtime ?
- If not, what are my other options ?
Thank you,
Nicolas
Hi Nicolas,
According to documentation, OpenVINO™ Toolkit version 2020.3 is supported by Microsoft Visual Studio with C++ 2019, 2017, or 2015 with MSBuild.
This installer is still available on download page:
Peh
Hi Peh,
Thank you, everything worked fine.
I have another question, is it easy to compile OpenVINO Runtime into a dll ?
Nicolas
Hi Nicolas,
Glad to hear you are doing well.
Compiling OpenVINO runtime into a .dll is not straightforward and not easy but it is doable. The idea to do so can refer to this GitHub discussion.
Peh
Hi Nicolas,
This thread will no longer be monitored since we have provided a solution and answer. If you need any additional information from Intel, please submit a new question.
Peh
