Unable to build OMZ demos (2022.3.0)
Jayabalaji
OpenVino version : 2022.3.0
Host OS: Ubuntu 20.04
Dear Team,
I am unable to build the Open Model Zoo demos as described in the below section,
https://docs.openvino.ai/2022.3/omz_demos.html
I am unable to find the below mentioned script and hence can't source it.
source <INSTALL_DIR>/setupvars.sh
I don't  "Openvino" folder in this path /opt/intel/ , which used to be present in the earlier versions, where the openvino environment is sourced.
Any pointers to resolve my issue is greatly appreciate.
JB
IntelSupport
Community Manager
Hi JB,
The installation folder using APT will be in /usr/include/openvino directory. To build samples, run build_samples.sh as mentioned in Step 5 from Install Intel® Distribution of OpenVINO™ Toolkit for Linux Using APT Repository.
As for Open Model Zoo(OMZ) demos, you have to Git clone OMZ manually.
Aznie
IntelSupport
Community Manager
Hi JB,
Thanks for reaching out.
To build the demos, you need to install the binary package of OpenVINO.
Follow the steps below:
  1. Go to Intel® Distribution of OpenVINO™ toolkit.
  2. Select Runtime
  3. Select Linux
  4. Select Version 2022.3
  5. Select Language C++
  6. Then, click Download Archives
  7. Extract the files as shown in Step 1 point 4 from Installing OpenVINO Runtime and you will see the installation directory.
Aznie
Jayabalaji
Hello Aznie,
Thanks for your reply.
I am installing runtime using APT distribution (Runtime -> Linux -> 2022.3 -> python -> APT), in this case do you know where I can find the installation directory?
Does the open model zoo demos are available after installation in the install directory?
JB
IntelSupport
Community Manager
Hi JB,
Aznie
IntelSupport
Community Manager
Hi JB,
This thread will no longer be monitored since we have provided information. If you need any additional information from Intel, please submit a new question.
Aznie
