Unable to convert tf model to IR
Snehal_H_Intel
I retrain inception_v3 model and was trying to convert it to IR format using model optimizer but I get the following error. Any way to solve this issue?
[ ERROR ]  -------------------------------------------------
[ ERROR ]  ----------------- INTERNAL ERROR ----------------
[ ERROR ]  Unexpected exception happened.
[ ERROR ]  Please contact Model Optimizer developers and forward the following information:
[ ERROR ]  local variable 'new_attrs' referenced before assignment
[ ERROR ]  Traceback (most recent call last):
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\front\extractor.py", line 749, in extract_node_attrs
    supported, new_attrs = extractor(Node(graph, node))
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\pipeline\tf.py", line 104, in <lambda>
    extract_node_attrs(graph, lambda node: tf_op_extractor(node, check_for_duplicates(tf_op_extractors)))
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\front\tf\extractor.py", line 92, in tf_op_extractor
    attrs = tf_op_extractors[op](node)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\front\common\register_custom_ops.py", line 96, in <lambda>
    node, cls, disable_omitting_optional, enable_flattening_optional_params),
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\front\common\register_custom_ops.py", line 29, in extension_extractor
    supported = ex.extract(node)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\extensions\front\tf\const_ext.py", line 32, in extract
    'value': tf_tensor_content(pb_tensor.dtype, shape, pb_tensor),
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\front\tf\extractors\utils.py", line 76, in tf_tensor_content
    dtype=type_helper[0]),
UnicodeDecodeError: 'ascii' codec can't decode byte 0xff in position 0: ordinal not in range(128)
During handling of the above exception, another exception occurred:
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\main.py", line 314, in main
    return driver(argv)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\main.py", line 281, in driver
    ret_res = emit_ir(prepare_ir(argv), argv)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\main.py", line 226, in prepare_ir
    graph = mo_tf.driver(argv)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\pipeline\tf.py", line 104, in driver
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\front\extractor.py", line 755, in extract_node_attrs
    new_attrs['name'] if 'name' in new_attrs else '<UNKNOWN>',
UnboundLocalError: local variable 'new_attrs' referenced before assignment
[ ERROR ]  ---------------- END OF BUG REPORT --------------
SuryaPSC_Intel
Hi snhase,
Can you share the below details:
  • What is the version of OpenVINO?
  • What is the version of Tensorflow?
  • What command you used to optimize the model?
Can you share the model and necessary files so that we can replicate the optimization at our end. If required, I can send a PM to share the model privately.
Surya
Mathias__Manpasu
Hi, thanks for reply. I got this error when I tried running the demo program that came with the OpenVINO. I had same error with openvino_2019.3.379 which made me upgrade to 2020.1.033. unfortunately i had same error too.
I CD into the bin directory and run the setupvars.bat
Then CD into the model_optimizer directory to configure the model optimizer by running the install_prerequisites.bat.
After running the file I got message on the console that all conditions are satisfied.
But whenever I CD into the demo directory to run the demo files, I get this error...
Snehal_H_Intel
Hello Surya,
Here is the info :
What is the version of OpenVINO?- 2020.1.033
What is the version of Tensorflow ? -   1.14.0
python3 mo_tf.py --input_model retrained_model.pb --output_dir .\IR_model\ --mean_values [128,128,128] --scale_values [299,299,299]
pythonversion- 3.6.9
So I went through this page on openvino website  to see all the supported model and saw that inception_v3_2016_08_28  is listed. The model version I retrained is inception-2015-12-05. Does the platform work only for the supported inception_v3 version and not previous versions?
Also, I can send you the model via PM if needed to duplicate.
Thanks!
snhase
SuryaPSC_Intel
Hi Snhase,
It is recommended to use only the supported models.
Try to use inception_v3_2016_08_28 model and let us know if the issue still persists.
Surya
SuryaPSC_Intel
Hi Manpasu,
  • Which demo and model are you using?
  • What command are you using to execute the demo?
Surya
Mathias__Manpasu
Hi, Chauhan,
Thanks for your reply. I figured out the cause of the problem.
Snehal_H_Intel
Hello Surya,
I fine tuned inception_v3_2016_08_28 model following the tf-slim instructions and the froze the resultant pbtxt and meta graph  files to get a frozen .pb model and then tried to push it through the model optimizer and I am still unable to convert it to IR format. Here is the error I see :
[ ERROR ]  Unexpected exception happened during extracting attributes for node case/cond/is_jpeg/Substr.
Original exception message: 'ascii' codec can't decode byte 0xff in position 0: ordinal not in range(128)
That's the entire error I see. Any ideas?
snhase
SuryaPSC_Intel
Hi Snhase,
Can you mention the command you used to freeze the model?
Have you used –input_type image_tensor parameter while freezing the model?
You may also refer this article to freeze tensorflow model.
Feel free to ask any other question.
Surya
Snehal_H_Intel
Hello Surya,
Thanks for your reply. My bad, I was using all the nodes instead of just one. I changed the output node to be only the output node for inception_v3 (InceptionV3/Predictions/Reshape_1) and then froze the graph. This is code snippet I used  to freeze the graph :
with tf.Session() as sess:
    saver = tf.train.import_meta_graph(cwdpath+'\\inception_v3_finetuned\\model.ckpt-2.meta')
    saver.restore(sess,tf.train.latest_checkpoint(cwdpath+'\\inception_v3_finetuned\\'))
    frozen_graph_def = tf.graph_util.convert_variables_to_constants(sess,sess.graph_def,['InceptionV3/Predictions/Reshape_1'])
    with open('frozen_graph_v2.pb', 'wb') as f:
        f.write(frozen_graph_def.SerializeToString())
Then tried to put it through the optimizer and get a new error now even though the frozen graph is not empty :
[ ERROR ]  Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.front.output_cut.OutputCut'>): Graph contains 0 node after executing <class 'extensions.front.output_cut.OutputCut'>. It considered as error because resulting IR will be empty which is not usual.
I also tried using the export_graph function you guided me to, even with that I get the following error when putting through the optimizer :
[ ERROR ]  Cannot infer shapes or values for node "InceptionV3/Logits/Conv2d_1c_1x1/biases".
[ ERROR ]  Attempting to use uninitialized value InceptionV3/Logits/Conv2d_1c_1x1/biases
         [[{{node _retval_InceptionV3/Logits/Conv2d_1c_1x1/biases_0_0}}]]
[ ERROR ]
[ ERROR ]  It can happen due to bug in custom shape infer function <function tf_native_tf_node_infer at 0x000001D393DC6BF8>.
[ ERROR ]  Or because the node inputs have incorrect values/shapes.
[ ERROR ]  Or because input shapes are incorrect (embedded to the model or passed via --input_shape).
[ ERROR ]  Run Model Optimizer with --log_level=DEBUG for more information.
[ ERROR ]  Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.middle.PartialInfer.PartialInfer'>): Stopped shape/value propagation at "InceptionV3/Logits/Conv2d_1c_1x1/biases" node.
 For more information please refer to Model Optimizer FAQ (https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_Model_Optimizer_FAQ.html), question #38.
Here is the freeze command I used :
python export_inference_graph.py --input_type image_tensor --trained_checkpoint_prefix ".\inception_v3_finetuned\model.ckpt-2.meta" --output_file frozen_inception_v3.pb
Is something wrong with the commands that's exporting wrong frozen graphs? I am new to tensorflow and openvino so now at a loss,  not sure how to proceed now. Any suggestions?
Snehal
SuryaPSC_Intel
Hi Snhase,
Surya
Snehal_H_Intel
Hi Surya,
Here is the model optimizer command I used :
python mo_tf.py --input_model "C:\Users\inception_v3_finetuned\frozen_v4.pb" --output_dir "C:\Users\inception_v3_finetuned" --mean_values [128,128,128] --scale_values [299,299,299]
The model files altogether are larger than 250mb so can't attach it. Here is a google drive link, let me know if you can access it.
https://drive.google.com/open?id=1A8NBSBbKa6HUv3cATtvns_7UbtQ5bzX8 ;
Also, just for debugging purposes, I tried convert the inception_v3 model as is without any fine tuning, I used the the export_inference_graph.py  tool provided by tf-slim to export out a .pb inference graph from the latest checkpoint file and I still get the same error
[ ERROR ]
[ ERROR ]  It can happen due to bug in custom shape infer function <function tf_native_tf_node_infer at 0x00000278D9018BF8>.
Command used for creating inference graph and model optimizer are as follows :
python export_inference_graph.py --alsologtostderr --model_name=inception_v3 --output_file=C:\tmp\inception_v3_inf_graph.pb
python mo_tf.py --input_model C:\tmp\inception_v3_2016\inception_v3_inf_graph.pb --output_dir "C:\tmp\inception_v3_2016" --mean_values [128,128,128] --scale_values [299,299,299]
This is confusing to me..why am I not able to to do this without an error?
Snehal
Snehal_H_Intel
Hello Surya,
After some more debugging, I figured out the problem was with the how I was freezing the exported graphs for the supported models. On using the freeze_graph tool by tensorflow. I can now convert the inception_v3 model as is model to the IR format. Then I tried the same with my fine tuned model and realized it was failing because my input node was a fifo queue instead of the default inception_v3 input [?,299,299,3] so I modified the input to match the inception_v3_2016_08_28 input , now I get a new error :
 WARNING ]  Please set `version` attribute for node InceptionV3/Logits/Dropout_1b/dropout/random_uniform/RandomUniform with type=<UNKNOWN>
[ ERROR ]  List of operations that cannot be converted to Inference Engine IR:
[ ERROR ]      RandomUniform (1)
[ ERROR ]          InceptionV3/Logits/Dropout_1b/dropout/random_uniform/RandomUniform
[ ERROR ]  Part of the nodes was not converted to IR. Stopped.
 For more information please refer to Model Optimizer FAQ (https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_Model_Optimizer_FAQ.html), question #2
I believe random uniform is not a supported op, some cursory google search shows this is a tf2 op but I am not sure how/why this operation was used during fine tuning, I trained in tf 1.14. Any ideas or solutions of how to resolve this?
snhase
