Unable to install SDK
$ sudo make install
./uninstall-opencv.sh
make install starting.
./install.sh
--2018-05-22 18:41:58-- https://software.intel.com/sites/default/files/managed/33/1b/NCSDK-1.12.00.01.tar.gz
Resolving proxy62.iitd.ac.in (proxy62.iitd.ac.in)… 10.10.78.62
Connecting to proxy62.iitd.ac.in (proxy62.iitd.ac.in)|10.10.78.62|:3128… connected.
Proxy request sent, awaiting response… 200 OK
Length: 975174 (952K) [application/octet-stream]
Saving to: ‘NCSDK-1.12.tar.gz’
NCSDK-1.12.tar.gz 100%[====================================================================================>] 952.32K --.-KB/s in 0.02s
2018-05-22 18:41:59 (43.4 MB/s) - ‘NCSDK-1.12.tar.gz’ saved [975174/975174]
Movidius Neural Compute Toolkit Setup.
Checking OS and version…
Installing on Ubuntu 16.04
Installer NCSDK version: 1.12.00.01
Creating setup directory…
Remove previous NCSDK references from PYTHONPATH…done
Checking whether tensorflow is installed…
looking for tensorflow CPU version…
Found tensorflow CPU version 1.4.0.
tensorflow already at latest supported version…skipping.
Caffe not found, installing caffe…
/opt/movidius/ssd-caffe
HEAD is now at 4817bf8 Merge pull request #791 from eselkin/ssd
Already on 'ssd'
Your branch is up-to-date with 'origin/ssd'.
Already up-to-date.
Already on 'ssd'
Compiling Caffe…
-- Boost version: 1.64.0
-- Found the following Boost libraries:
-- system
-- thread
-- filesystem
-- regex
-- Found gflags (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libgflags.so)
-- Found glog (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libglog.so)
-- Found PROTOBUF Compiler: /usr/bin/protoc
-- Found lmdb (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/liblmdb.so)
-- Found LevelDB (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libleveldb.so)
-- Found Snappy (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libsnappy.so)
-- -- CUDA is disabled. Building without it…
CMake Error at /usr/share/cmake-3.5/Modules/FindPackageHandleStandardArgs.cmake:148 (message):
Could NOT find CUDA: Found unsuitable version "7.5", but required is exact
version "9.0" (found /usr)
Call Stack (most recent call first):
/usr/share/cmake-3.5/Modules/FindPackageHandleStandardArgs.cmake:386 (_FPHSA_FAILURE_MESSAGE)
/usr/share/cmake-3.5/Modules/FindCUDA.cmake:949 (find_package_handle_standard_args)
/usr/local/share/OpenCV/OpenCVConfig.cmake:86 (find_package)
/usr/local/share/OpenCV/OpenCVConfig.cmake:105 (find_host_package)
cmake/Dependencies.cmake:72 (find_package)
CMakeLists.txt:43 (include)
-- Configuring incomplete, errors occurred!
See also "/opt/movidius/ssd-caffe/build/CMakeFiles/CMakeOutput.log".
See also "/opt/movidius/ssd-caffe/build/CMakeFiles/CMakeError.log".
make[1]: Entering directory '/opt/movidius/ssd-caffe/build'
make[1]: *** No rule to make target 'all'. Stop.
make[1]: Leaving directory '/opt/movidius/ssd-caffe/build'
Installing caffe…
make[1]: *** No rule to make target 'install'. Stop.
Installation failed. Error on line 498
I am not able to find out why it cannot find cuda9 Any help appreciated
