Unsupported Activation layer type: exp" ?
taka
hi
Unable to execute models containing exp layer.
For example, mobilenet model saved with tr_keras.
Model creation method
import tensorflow as tf
from tensorflow import keras
pretrained_model = tf.keras.applications.MobileNet()
# Export the model to a SavedModel
keras.experimental.export_saved_model(pretrained_model, './tmp/mobileNet/keras
Model_Optimaizer command
"python mo.py --saved_model_dir .\tmp\mobileNet\keras --output_dir movilenet -b 1"
Conversion of model optimizer can be done without problems.
The following error occurs when running with benchmark_ap
"[ ERROR ] Error reading network: Unsupported Activation layer type: exp"
Is "exp" not supported?
However, the release notes for R2019 have the following descriptions
New and Changed in the Release 1
CPU plugin
 Added new Activation types:
 Exp
Are there plans to support "exp layer" on VPU and GPU?
Shubha_R_Intel
Dear Taka,
There is a known bug which causes the Unsupported Activation layer type: exp.  In the next release of OpenVino it is fixed, however. Thanks for your patience !
Shubha
taka
Thank you !
Does VPU and GPU already support "exp"?
If not, do you have any plans?
Shubha_R_Intel
Dear taka, according the IR Layers Catalog exp is in the category of Activation function. Yes, it probably should be supported in VPU and GPU but the Supported Devices document doesn't mention it. I will file a bug on this omission. Activation-Exp should be mentioned and it's not.
Shubha
Shubha_R_Intel
Dear taka,
Please download the latest OpenVino 2019 R1.1.  This bug should be fixed.
Thanks !
Shubha
taka
Dear Shubha,
In Open VIno 2019R1.1, I think that the bug is not fixed yet.
(I tried with "w_openvino_toolkit_p_2019.1.148.exe".)
Shubha_R_Intel
Dear taka,
Please kindly attach your generated IR here. Let me take a look...
Thanks !
Shubha
taka
Shubha_R_Intel
Dear taka,
Try a new entry node in your model optimizer command. So to create IR, add the following  --input 0:conv1/Conv2D
More info about the technique here:
http://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_convert_model_Cutting_Model.html
Just add that as another switch to your model optimizer command, generate a new IR and re-run inference. Let me know how it works.
Thanks for using OpenVino !
Shubha
taka
Dear Shubha,
The result has not changed.
Shubha_R_Intel
Dearest taka, did you try what I suggested above, i.e. add the following  --input 0:conv1/Conv2D to your model optimizer command ? Please give me your entire model optimizer command.
Also kindly in a zip file attach your Keras model.
Thanks !
Shubha
taka
Dear Shubha,
Attach keras model.
I tried the following two types, but it did not work.
python mo.py --saved_model_dir .\mobileNet --output_dir movilenet -b 1
python mo.py --saved_model_dir .\mobileNet --output_dir movilenet -b 1 --input 0:conv1/Conv2D
Shubha_R_Intel
Dear taka, you have found a bug and I reproduced it. Really sorry for the inconvenience !
Shubha
