Dear all thanks for your time,
Setup :
- Up Squared
- Intel® Pentium® Processor N4200
- UP AI Core X with the Myriad 2485
- Ubuntu 18.04.2 LTS
- linux 4.15.0-55-generic
I'm trying to install the Version 2019_R2 on the card, so I just followed:
- the general installation procedure at https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux.html#install-openvino
- the Visual Accelerator Design config at https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux_ivad_vpu.html
The demo on CPU work correctly.
But neither on MYRIAD nor the HDDL work. It seems like the chip is not recognized by the OS.
The MYRIAD test:
Run Inference Engine classification sample
Run ./classification_sample_async -d MYRIAD -i /opt/intel/openvino/deployment_tools/demo/car.png -m /home/deepo/openvino_models/ir/FP16//classification/squeezenet/1.1/caffe/squeezenet1.1.xml
[ INFO ] InferenceEngine:
API version ............ 2.0
Build .................. custom_releases/2019/R2_f5827d4773ebbe727c9acac5f007f7d94dd4be4e
Description ....... API
[ INFO ] Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ] /opt/intel/openvino/deployment_tools/demo/car.png
[ INFO ] Creating Inference Engine
MYRIAD
myriadPlugin version ......... 2.0
Build ........... 27579
[ INFO ] Loading network files
[ INFO ] Preparing input blobs
[ WARNING ] Image is resized from (787, 259) to (227, 227)
[ INFO ] Batch size is 1
[ INFO ] Loading model to the device
[ ERROR ] Can not init Myriad device: NC_ERROR
Error on or near line 238; exiting with status 1
The HDDL test:
Run ./classification_sample_async -d HDDL -i /opt/intel/openvino/deployment_tools/demo/car.png -m /home/deepo/openvino_models/ir/FP16//classification/squeezenet/1.1/caffe/squeezenet1.1.xml
HDDL
HDDLPlugin version ......... 2.0
[17:10:46.5933][5128]I[FileHelper.cpp:272] Set file:/var/tmp/hddl_autoboot_ready.mutex owner: user-'no_change', group-'users', mode-'0660'
[17:10:46.5934][5128]I[FileHelper.cpp:272] Set file:/var/tmp/hddl_autoboot_start_exit.mutex owner: user-'no_change', group-'users', mode-'0660'
[17:10:46.5935][5128]I[FileHelper.cpp:272] Set file:/tmp/hddl_autoboot_device.map owner: user-'no_change', group-'users', mode-'0660'
[17:10:46.5936][5128]I[AutoBoot.cpp:300] [Firmware Config] deviceName=default deviceNum=0 firmwarePath=/opt/intel/openvino_2019.2.242/deployment_tools/inference_engine/external/hddl/lib/mvnc/MvNCAPI-ma2x8x.mvcmd
Config file detected at /opt/intel/openvino_2019.2.242/deployment_tools/inference_engine/external/hddl/config/bsl.json
[ion_close][69]close ion_fd = 3
[17:10:47.5840][5126]I[AutobootStarter.cpp:78] Info: Service has been waiting for Autoboot to boot up for 1 seconds ... [0/18126]
[17:10:48.5867][5126]I[AutobootStarter.cpp:78] Info: Service has been waiting for Autoboot to boot up for 2 seconds ...
[17:10:49.5886][5126]I[AutobootStarter.cpp:78] Info: Service has been waiting for Autoboot to boot up for 3 seconds ...
[17:11:16.6564][5126]W[AutobootStarter.cpp:98]
** Suggestion: The timeout by default is 10 seconds, and you can increase it by following steps:
(1) Add following entry in $HDDL_INSTALL_DIR/config/hddl_service.config like this:
"service_settings":
"autoboot_boot_timeout_sec": 10,
(2) Change the '10' to a larger value to increase the time out window, then try again.
[17:11:16.6565][5126]ERROR[AutobootStarter.cpp:48] Error: Failed to start autoboot
[17:11:16.6565][5126]ERROR[main.cpp:76] Error: Start Service failed due to autoboot failure
Can you help me to figure out where I'm making a mistake ?
Thanks!!
Dear breschi, iacopo,
you probably need to revisit the details of the below doc:
Or maybe just reboot if you really performed all HDDL installation steps.
Hope it helps,
Shubha
Dear Shubha,
many thanks for your reply. It's three days that I'm stuck on this problem and it's very frustrating.
Your advice is interesting. Should I really follow the additional-NCS-steps even if I have the mini pcie card?
Anyway I followed the doc many times installing, uninstalling and reinstalling. Rebooted numerous times, checked every step but unfortunately without success. Here follow few logs of my system, I hope you can help me debug a little! THANKS
This are my usb devices:
lsusb Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 002: ID 046d:c31c Logitech, Inc. Keyboard K120 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Here the top part of lspci:
lspci 00:00.0 Host bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series Host Bridge (rev 0b) 00:02.0 VGA compatible controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series Integrated Graphics Controller (rev 0b) 00:0e.0 Multimedia audio controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster (rev 0b) 00:0f.0 Communication controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series Trusted Execution Engine (rev 0b) 00:11.0 Unclassified device [0050]: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series Integrated Sensor Hub (rev 0b) 00:12.0 SATA controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series SATA AHCI Controller (rev 0b) 00:13.0 PCI bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port A #1 (rev fb) <--- Behind this one I think should be the pcie card with the Myriad 00:13.1 PCI bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port A #2 (rev fb) 00:13.2 PCI bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port A #3 (rev fb) 00:13.3 PCI bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port A #4 (rev fb) 00:14.0 PCI bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port B #1 (rev fb) 00:14.1 PCI bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port B #2 (rev fb) 00:15.0 USB controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series USB xHCI (rev 0b) 00:15.1 USB controller: Intel Corporation Device 5aaa (rev 0b)
I'm thinking that the OS is having problem to talk to the card. I have this series of logs in the dmesg on the usb3 that I suppose being the one connected to the pci card.
[ 2.575378] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.577469] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.579512] usb usb3: Product: xHCI Host Controller [ 2.581550] usb usb3: Manufacturer: Linux 4.15.0-55-generic xhci-hcd [ 2.583604] usb usb3: SerialNumber: 0000:01:00.0 [ 2.928065] usb 3-1: new full-speed USB device number 2 using xhci_hcd [ 2.929352] usb 3-1: Device not responding to setup address. [ 3.136610] usb 3-1: Device not responding to setup address. [ 3.344282] usb 3-1: device not accepting address 2, error -71 [ 3.472284] usb 3-1: new full-speed USB device number 3 using xhci_hcd [ 3.474243] usb 3-1: Device not responding to setup address. [ 3.680564] usb 3-1: Device not responding to setup address. [ 3.888178] usb 3-1: device not accepting address 3, error -71 [ 3.888267] usb usb3-port1: attempt power cycle [ 4.540025] usb 3-1: new full-speed USB device number 4 using xhci_hcd [ 4.668026] usb 3-1: device descriptor read/64, error -71 [ 4.904485] usb 3-1: device descriptor read/64, error -71 [ 5.140284] usb 3-1: new full-speed USB device number 5 using xhci_hcd [ 5.268568] usb 3-1: device descriptor read/64, error -71 [ 5.504577] usb 3-1: device descriptor read/64, error -71 [ 5.612388] usb usb3-port1: unable to enumerate USB device:
I tried many things to solve usb error -71, such as setting in the grub to the following line, but nothing changed.
GRUB_CMDLINE_LINUX_DEFAULT="usbcore.autosuspend=-1 usbcore.old_scheme_first=y"
Maybe Ubuntu 18.04 is conflicting somehow. What do you think?
Thanks again for the help!
Ubuntu 18 could indeed be the issue. Please see Jesus's response to this IDZ post .Please study the workaround Jesus suggests. I guess that the OS can't find the drivers.
The workaround is to extract package intel-openvino-ie-rt-vpu-ubuntu-bionic-2019.1.094-2019.1-094.x86_64.rpm manually.
Hope it helps.
Shubha
Dear Shubha,
thanks for your help.
I already tried to check if the rpm was correctly extracted, and it was.
I was desperate so I bought a new Movidious pcie card. I plugged into my up2board and now it's working! I really think it was an hardware problem.
For record here few logs:
As you can see now the usb 3-1 is able to recognize the card. Here my dmesg:
[ 2.514846] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.514858] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.514867] usb usb3: Product: xHCI Host Controller [ 2.514874] usb usb3: Manufacturer: Linux 4.15.0-55-generic xhci-hcd [ 2.514882] usb usb3: SerialNumber: 0000:01:00.0 [ 2.860068] usb 3-1: new high-speed USB device number 2 using xhci_hcd [ 2.885285] usb 3-1: New USB device found, idVendor=03e7, idProduct=2150 <--------- Good [ 2.885291] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 2.885296] usb 3-1: Product: Movidius MA2X5X [ 2.885299] usb 3-1: Manufacturer: Movidius Ltd. [ 2.885302] usb 3-1: SerialNumber: 03e72150 [ 8.053229] usbcore: registered new interface driver myriad_usb_vsc [ 500.562932] usb 3-1: USB disconnect, device number 2 [ 502.674870] usb 3-1: new high-speed USB device number 3 using xhci_hcd [ 502.695476] usb 3-1: New USB device found, idVendor=03e7, idProduct=2150 [ 502.695480] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 502.695482] usb 3-1: Product: Movidius MA2X5X [ 502.695484] usb 3-1: Manufacturer: Movidius Ltd. [ 502.695486] usb 3-1: SerialNumber: 03e72150
when before I had:
[ 2.575378] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.577469] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.579512] usb usb3: Product: xHCI Host Controller [ 2.581550] usb usb3: Manufacturer: Linux 4.15.0-55-generic xhci-hcd [ 2.583604] usb usb3: SerialNumber: 0000:01:00.0 [ 2.928065] usb 3-1: new full-speed USB device number 2 using xhci_hcd [ 2.929352] usb 3-1: Device not responding to setup address. <--------- Bad [ 3.136610] usb 3-1: Device not responding to setup address. [ 3.344282] usb 3-1: device not accepting address 2, error -71
Thanks again and regards
Dearest breschi, iacopo,
I certainly understand that feeling of desperation ! I have been there before too ! But I'm super glad you finally got it working. Thanks so much for sharing your success with the OpenVino community !
Shubha
