Up Squared with UP AI Core X not working
breschi__iacopo
Dear all thanks for your time,
Setup :
  • Up Squared
  • Intel® Pentium® Processor N4200
  • UP AI Core X with the Myriad 2485
  • Ubuntu 18.04.2 LTS
  • linux 4.15.0-55-generic
I'm trying to install the Version 2019_R2 on the card, so I just followed:
The demo on CPU work correctly.
But neither on MYRIAD nor the HDDL work. It seems like the chip is not recognized by the OS.
The MYRIAD test:
Run Inference Engine classification sample
Run ./classification_sample_async -d MYRIAD -i /opt/intel/openvino/deployment_tools/demo/car.png -m /home/deepo/openvino_models/ir/FP16//classification/squeezenet/1.1/caffe/squeezenet1.1.xml
[ INFO ] InferenceEngine:
        API version ............ 2.0
        Build .................. custom_releases/2019/R2_f5827d4773ebbe727c9acac5f007f7d94dd4be4e
        Description ....... API
[ INFO ] Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ]     /opt/intel/openvino/deployment_tools/demo/car.png
[ INFO ] Creating Inference Engine
        MYRIAD
        myriadPlugin version ......... 2.0
        Build ........... 27579
[ INFO ] Loading network files
[ INFO ] Preparing input blobs
[ WARNING ] Image is resized from (787, 259) to (227, 227)
[ INFO ] Batch size is 1
[ INFO ] Loading model to the device
[ ERROR ] Can not init Myriad device: NC_ERROR
Error on or near line 238; exiting with status 1
The HDDL test:
Run ./classification_sample_async -d HDDL -i /opt/intel/openvino/deployment_tools/demo/car.png -m /home/deepo/openvino_models/ir/FP16//classification/squeezenet/1.1/caffe/squeezenet1.1.xml
        HDDL
        HDDLPlugin version ......... 2.0
[17:10:46.5933][5128]I[FileHelper.cpp:272] Set file:/var/tmp/hddl_autoboot_ready.mutex owner: user-'no_change', group-'users', mode-'0660'
[17:10:46.5934][5128]I[FileHelper.cpp:272] Set file:/var/tmp/hddl_autoboot_start_exit.mutex owner: user-'no_change', group-'users', mode-'0660'
[17:10:46.5935][5128]I[FileHelper.cpp:272] Set file:/tmp/hddl_autoboot_device.map owner: user-'no_change', group-'users', mode-'0660'
[17:10:46.5936][5128]I[AutoBoot.cpp:300] [Firmware Config] deviceName=default deviceNum=0 firmwarePath=/opt/intel/openvino_2019.2.242/deployment_tools/inference_engine/external/hddl/lib/mvnc/MvNCAPI-ma2x8x.mvcmd
 Config file detected at /opt/intel/openvino_2019.2.242/deployment_tools/inference_engine/external/hddl/config/bsl.json
[ion_close][69]close ion_fd = 3
[17:10:47.5840][5126]I[AutobootStarter.cpp:78] Info: Service has been waiting for Autoboot to boot up for 1 seconds ...        [0/18126]
[17:10:48.5867][5126]I[AutobootStarter.cpp:78] Info: Service has been waiting for Autoboot to boot up for 2 seconds ...
[17:10:49.5886][5126]I[AutobootStarter.cpp:78] Info: Service has been waiting for Autoboot to boot up for 3 seconds ...
[17:11:16.6564][5126]W[AutobootStarter.cpp:98]
      ** Suggestion: The timeout by default is 10 seconds, and you can increase it by following steps:
            (1) Add following entry in $HDDL_INSTALL_DIR/config/hddl_service.config like this:
                   "service_settings":
                     "autoboot_boot_timeout_sec":   10,
            (2) Change the '10' to a larger value to increase the time out window, then try again.
[17:11:16.6565][5126]ERROR[AutobootStarter.cpp:48] Error: Failed to start autoboot
[17:11:16.6565][5126]ERROR[main.cpp:76] Error: Start Service failed due to autoboot failure
Can you help me to figure out where I'm making a mistake ?
Thanks!!
Shubha_R_Intel
Dear breschi, iacopo,
you probably need to revisit the details of the below doc:
https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux.html#additional-NCS-steps
Or maybe just reboot if you really performed all HDDL installation steps.
Hope it helps,
Shubha
breschi__iacopo
Dear Shubha,
many thanks for your reply. It's three days that I'm stuck on this problem and it's very frustrating.
Your advice is interesting. Should I really follow the additional-NCS-steps even if I have the mini pcie card?
Anyway I followed the doc many times installing, uninstalling and reinstalling. Rebooted numerous times, checked every step but unfortunately without success. Here follow few logs of my system, I hope you can help me debug a little! THANKS
This are my usb devices:
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 046d:c31c Logitech, Inc. Keyboard K120
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Here the top part of lspci:
lspci
00:00.0 Host bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series Host Bridge (rev 0b)
00:02.0 VGA compatible controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series Integrated Graphics Controller (rev 0b)
00:0e.0 Multimedia audio controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster (rev 0b)
00:0f.0 Communication controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series Trusted Execution Engine (rev 0b)
00:11.0 Unclassified device [0050]: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series Integrated Sensor Hub (rev 0b)
00:12.0 SATA controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series SATA AHCI Controller (rev 0b)
00:13.0 PCI bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port A #1 (rev fb)      <--- Behind this one I think should be the pcie card with the Myriad
00:13.1 PCI bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port A #2 (rev fb)
00:13.2 PCI bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port A #3 (rev fb)
00:13.3 PCI bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port A #4 (rev fb)
00:14.0 PCI bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port B #1 (rev fb)
00:14.1 PCI bridge: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series PCI Express Port B #2 (rev fb)
00:15.0 USB controller: Intel Corporation Celeron N3350/Pentium N4200/Atom E3900 Series USB xHCI (rev 0b)
00:15.1 USB controller: Intel Corporation Device 5aaa (rev 0b)
I'm thinking that the OS is having problem to talk to the card. I have this series of logs in the dmesg on the usb3 that I suppose being the one connected to the pci card.
[    2.575378] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    2.577469] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.579512] usb usb3: Product: xHCI Host Controller
[    2.581550] usb usb3: Manufacturer: Linux 4.15.0-55-generic xhci-hcd
[    2.583604] usb usb3: SerialNumber: 0000:01:00.0
[    2.928065] usb 3-1: new full-speed USB device number 2 using xhci_hcd
[    2.929352] usb 3-1: Device not responding to setup address.
[    3.136610] usb 3-1: Device not responding to setup address.
[    3.344282] usb 3-1: device not accepting address 2, error -71
[    3.472284] usb 3-1: new full-speed USB device number 3 using xhci_hcd
[    3.474243] usb 3-1: Device not responding to setup address.
[    3.680564] usb 3-1: Device not responding to setup address.
[    3.888178] usb 3-1: device not accepting address 3, error -71
[    3.888267] usb usb3-port1: attempt power cycle
[    4.540025] usb 3-1: new full-speed USB device number 4 using xhci_hcd
[    4.668026] usb 3-1: device descriptor read/64, error -71
[    4.904485] usb 3-1: device descriptor read/64, error -71
[    5.140284] usb 3-1: new full-speed USB device number 5 using xhci_hcd
[    5.268568] usb 3-1: device descriptor read/64, error -71
[    5.504577] usb 3-1: device descriptor read/64, error -71
[    5.612388] usb usb3-port1: unable to enumerate USB device:
I tried many things to solve usb error -71, such as setting in the grub to the following line, but nothing changed.
GRUB_CMDLINE_LINUX_DEFAULT="usbcore.autosuspend=-1 usbcore.old_scheme_first=y"
Maybe Ubuntu 18.04 is conflicting somehow. What do you think?
Thanks again for the help!
Shubha_R_Intel
Ubuntu 18 could indeed be the issue. Please see Jesus's response to this IDZ post .Please study the workaround Jesus suggests.  I guess that the OS can't find the drivers.
The workaround is to extract package intel-openvino-ie-rt-vpu-ubuntu-bionic-2019.1.094-2019.1-094.x86_64.rpm manually.
Hope it helps.
Shubha
breschi__iacopo
Dear Shubha,
thanks for your help.
I already tried to check if the rpm was correctly extracted, and it was.
I was desperate so I bought a new Movidious pcie card. I plugged into my up2board and now it's working! I really think it was an hardware problem.
For record here few logs:
As you can see now the usb 3-1 is able to recognize the card. Here my dmesg:
[    2.514846] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    2.514858] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.514867] usb usb3: Product: xHCI Host Controller
[    2.514874] usb usb3: Manufacturer: Linux 4.15.0-55-generic xhci-hcd
[    2.514882] usb usb3: SerialNumber: 0000:01:00.0
[    2.860068] usb 3-1: new high-speed USB device number 2 using xhci_hcd
[    2.885285] usb 3-1: New USB device found, idVendor=03e7, idProduct=2150    <--------- Good
[    2.885291] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.885296] usb 3-1: Product: Movidius MA2X5X
[    2.885299] usb 3-1: Manufacturer: Movidius Ltd.
[    2.885302] usb 3-1: SerialNumber: 03e72150
[    8.053229] usbcore: registered new interface driver myriad_usb_vsc
[  500.562932] usb 3-1: USB disconnect, device number 2
[  502.674870] usb 3-1: new high-speed USB device number 3 using xhci_hcd
[  502.695476] usb 3-1: New USB device found, idVendor=03e7, idProduct=2150
[  502.695480] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  502.695482] usb 3-1: Product: Movidius MA2X5X
[  502.695484] usb 3-1: Manufacturer: Movidius Ltd.
[  502.695486] usb 3-1: SerialNumber: 03e72150
when before I had:
[    2.929352] usb 3-1: Device not responding to setup address.        <---------  Bad
Thanks again and regards
Shubha_R_Intel
Dearest breschi, iacopo,
I certainly understand that feeling of desperation ! I have been there before too ! But I'm super glad you finally got it working. Thanks so much for sharing your success with the OpenVino community !
Shubha
