6613 Discussions
UserWarning: You are using a large type. Consider reducing your data sizes for best performance
Hi,all!
Please help me to solve the following problem.
when I use the following command: mvNCCompile tcs_inference.meta -w tcs_inference -s 12 -in input -on output -o tsc_inference.graph
the output is: mvNCCompile v02.00, Copyright @ Movidius Ltd 2016
/usr/local/lib/python3.5/dist-packages/tensorflow/python/util/tf_inspect.py:45: DeprecationWarning: inspect.getargspec() is deprecated, use inspect.signature() instead
if d.decorator_argspec is not None), _inspect.getargspec(target))
/usr/local/bin/ncsdk/Controllers/FileIO.py:52: UserWarning: You are using a large type. Consider reducing your data sizes for best performance
"Consider reducing your data sizes for best performance\033[0m")
@guohua24
Both are warnings and I think that it can be ignored.
I ignore it because "Consider reducing your data sizes for best performance \ 033 [0 m]" is displayed every time.
I wonder if the graph file is generated without worrying about it.
