Using Faster RCNN Sample
HemanthKum_G_Intel
#Informative snippet for developers
Following instructions demonstrate the usage of Faster RCNN sample on Ubuntu having Intel Distribution of OpenVINO 2019 R3.1
wget http://download.tensorflow.org/models/object_detection/faster_rcnn_inception_v2_coco_2018_01_28.tar.gz
tar -xvf faster_rcnn_inception_v2_coco_2018_01_28.tar.gz
cd faster_rcnn_inception_v2_coco_2018_01_28/
source /opt/intel/openvino/bin/setupvars.sh
python3 /opt/intel/openvino/deployment_tools/model_optimizer/mo_tf.py \
--input_model frozen_inference_graph.pb \
--reverse_input_channels \
--tensorflow_object_detection_api_pipeline_config pipeline.config \
--output=detection_boxes,detection_scores,num_detections \
--tensorflow_use_custom_operations_config /opt/intel/openvino/deployment_tools/model_optimizer/extensions/front/tf/faster_rcnn_support.json
/home/administrator/inference_engine_samples_build/intel64/Release/object_detection_sample_ssd \
-i /opt/intel/openvino/deployment_tools/demo/car_1.bmp \
-m frozen_inference_graph.xml
Output:-
[ INFO ] InferenceEngine:
        API version ............ 2.1
        Build .................. custom_releases/2019/R3_89514d4cb7820ea78101bb4892dd8f16f5082916
        Description ....... API
Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ]     /opt/intel/openvino/deployment_tools/demo/car_1.bmp
[ INFO ] Loading Inference Engine
[ INFO ] Device info:
        CPU
        MKLDNNPlugin version ......... 2.1
        Build ........... 30886
[ INFO ] Loading network files:
        frozen_inference_graph.bin
[ INFO ] Preparing input blobs
[ INFO ] Batch size is 1
[ INFO ] Preparing output blobs
[ INFO ] Loading model to the device
[ INFO ] Create infer request
[ WARNING ] Image is resized from (749, 637) to (600, 600)
[ INFO ] Start inference
[ INFO ] Processing output blobs
[0,3] element, prob = 0.838253    (222,117)-(514,477) batch id : 0 WILL BE PRINTED!
[1,6] element, prob = 0.515723    (642,223)-(749,600) batch id : 0 WILL BE PRINTED!
[2,8] element, prob = 0.724386    (641,168)-(746,625) batch id : 0 WILL BE PRINTED!
[3,8] element, prob = 0.360326    (239,116)-(512,454) batch id : 0
[ INFO ] Image out_0.bmp created!
[ INFO ] Execution successful
JesusE_Intel
Hi Kumar,
Thank you for sharing the information with the developer community! I would like to add that we also have the Object Detection Faster RCNN C++ Demo available.
Jesus
Ali1
Hello Kumar,
Thank you for sharing that, I was looking all over for a way to get the object_detection_sample_ssd.py to work with Faster RCNN models or if there is another Python sample script for Faster RCNN models.
I have tried following your steps and got an error when trying to use the script for object detection. The model optimisation went fine but when trying to input images and detect objects it was a bit strange as the first time after the inference I did not get an error but the script did not provide any out.bmp but the second time I tried I got the errors  shown in the file attached below.
I would appreciate if you could let me know where I went wrong or if there is another python script I can use for Faster RCNN model types; I found the C++ implementation but I need a python script for the application I am looking for. I am trying to use a raspberry pi for real time object detection and the python script would make it easier to use the camera module for the video stream.
P.S My current openvino version is 2020.1.023 and it is installed on an Ubuntu 16.04 LTS virtual machine.
Ali1
Hello @HemanthKum_G_Intel @JesusE_Intel ,
I have sent an enquiry about two weeks ago but did not receive a response, is there anything wrong with my implementation/request or is this forum not monitored any more?
I would appreciate any feedback you could provide.
Thank you,
Kind regards,
Mahgoub
