Using OpenVINO with T265 camera
RobDubois
I would like to know if is possible to use OpenVINO with the T265 camera (and its movidius chip) like I do with a NCS stick ?
Is it possible to load a model and run inference on it ?
I ask this question, because when I launch the OpenVINO Hello Query Device Python Sample,  the camera (unique device plugged on my USB port) is listed with the same properties as a stick.
But when I try to run the benchmark sample (using MYRIAD as device) it stops on this error : Cannot init Myriad device : NC_ERROR
The same code perfectly runs on a NCS stick.
I had the same behavior on raspberry / windows10 / macOSX.
Is the movidius chip of the camera only dedicated for camera specific treatments (like VSLAM) ?
Thanks for your help !
JAVIERJOSE_A_Intel
Hi RobDubois,
Thanks for reaching out.
The Intel® RealSense™ Tracking Camera T265 only can be used with the RealSense SDK 2.0. It is only meant to run Intel® RealSense™ Visual SLAM.
While the T265 camera does have an Intel® Movidius™ Myriad™ chip, it is a custom solution and does not behave like a regular Intel® Movidius™ Neural Compute Stick.
Javier A.
JAVIERJOSE_A_Intel
Hi RobDubois,
Javier A.
RobDubois
Thanks a lot for your answer Javier !
Have a nice day.
Robert.
