Using Pre-trained models in NCS2
Kaliyappan__Malathi
I need a clarification about Neural Compute Stick 2 using pre-trained models.
Is it possible to use pedestrian detection and action recognition (models build in OpenVINO R3 version) in Intel neural compute stick 2 ?
Thanks in advance.
Luis_at_Intel
Hi Malathi,
You should be able to use the frames from IP camera with your NCS2. I found some threads from other users tying to do something similar with IP cameras and OpenVINO:
Hope this helps, let me know if you have additional questions.
Luis
Luis_at_Intel
Hi Kaliyappan, Malathi
Please take a look at this document as it has a list of the Pre-Trained models, supported demos and plugins. According to the document for pedestrian detection, action recognition models and Myriad plugin (NCS2) these are supported:
  • pedestrian-detection-adas-0002
  • person-detection-action-recognition-0005
Luis
Kaliyappan__Malathi
Hi Luis,
Thanks for response.
I need a clarification about deploying my model in NCS2
1) My OpenVINO action recognition model (Pre-trained) using IP camera for taking input in RTSP format (rtsp://admin:admin@192.168.1.108:554/cam/realmonitor?channel=1&subtype=0). Can please let me know If I can access the IP camera from NCS2, after I deploy the model on that.
Malathi
Luis_at_Intel
Hi Malathi,
Luis
