Weight from Model Optimiser Output
GMath7
Can you please guide me how, i can get weight values of a trained model from its IR form(xml and bin). I have converted a trained model to its IR (bin and xml) using Model Optimiser. I would like to know the weight values from the bin file to check whether I have correctly done the conversion. I have read the IR using the command below.
net = IENetwork.from_ir(model=<path_to_xml_file>, weights=<path_to_bin_file>)
It would be great if someone can help me at the earliest.
