6594 Discussions
Weird latency behavior - Multi models for multiple batch sizes
Huynh__Loc
Hi all, hope you could help me on this.
I have tried to run mobilenetv1 with dynamic batch size but got the "RuntimeError: MKLDNNGraph::CreateGraph: such topology cannot be compiled for dynamic batch!" error. Properly due to the squeeze layer inside mobilenetv1 that changes the shape of the tensor.
So in the end, I've decided to create multiple models for each batch size and did some benchmarks. But I got weird latency/throughput behavior.
My program is pretty simple
images = np.random.uniform(-1,1, size=[64, 3, 224, 224]).astype(np.float32)
for batch_size in range(1,16):
    #create model
    net = IENetwork(model=model_xml, weights=model_bin)
    net.batch_size = batch_size
    exec_net = plugin.load(network=net)
    input_blob = next(iter(net.inputs))
    #run inference
    batch = images[np.arange(batch_size)]
    res = exec_net.infer(inputs={input_blob: batch})
However, after 4 iterations, openvino started using only 1 single CPU core instead of all my CPU cores (I'm using Intel(R) Xeon(R) Gold 6140).
Batch_size: 1, Throughput: 643.86 imgs/s
Batch_size: 2, Throughput: 924.83 imgs/s
Batch_size: 3, Throughput: 1064.74 imgs/s
Batch_size: 4, Throughput: 1245.72 imgs/s
Batch_size: 5, Throughput: 168.25 imgs/s
Batch_size: 6, Throughput: 168.66 imgs/s
Do you have any suggestions to fix this problem?
Thank you
Khang_N_Intel
Hi Loc,
Based on the error message that you provided, it seems like your application has something to do with DNN and you are not using Intel(R) MKL.
This is the Intel(R) MKL forum.  Let me see if I can find the correct forum for you to post your question.
Best regards,
Khang
Huynh__Loc
Oops, sorry. I posted in a wrong forum. Should have posted into OpenVino forum.
Khang_N_Intel
Hi Loc,
No problem.  Yes, all the questions relating to OpenVino should post over there.
Khang
Huynh__Loc
Nguyen, Khang T (Intel) wrote:
Hi Loc,
Khang
Can you help me delete this post? I'll repost to OpenVino forum.
Thanks a lot :)
Gennady_F_Intel
the thread has been moved to the OpenVINO forum
