6580 Discussions
What are the inputs of license-plate-recognition-barrier-0001?
es__we
I want to rewrite the Security Barrier Camera Demo in python. However, I don't know how to use the "license-plate-recognition-barrier-0001". It seems that the model requires multiple inputs. What's the "seq_ind"? Are there eighty-seven 1‘s and one 0? Thanks.
es__we
solved!
Luis_at_Intel
Hi es,we
Thanks for reaching out. I believe that is correct, based on the license-plate-recognition-barrier-0001 document here the input seq_ind: "shape: [88,1] - An auxiliary blob that is needed for correct decoding. Set this to [0, 1, 1, ..., 1]". I've also found this where someone had a similar question about the inputs of the model.
Does this match your solution? Please kindly share so others can benefit from your findings. Thanks!
Luis
