6587 Discussions
What are the values for -ip in comiple_tool for MyriadX Bolb Converter
franva
I am using the online converting tool:
http://luxonis.com:8080/
It has a MyriadX compile params: textbox. Inside it there is `-ip`
I understand its the precision for all input layers, but I cannot find its acceptable values..
Could someone help please.
Syamimi_Intel
Hi Franva,
Yes, myriad_compile.exe is a part of OpenVINO. You can Build OpenVINO™ Inference Engine for Windows* systems  to run the myriad_compile.exe. The myriad_compile.exe is located at:
<INSTALL_DIR>\openvino\deployment_tools\inference_engine\bin\intel64\Release
On a separate note, you can also download and install Intel Distribution of OpenVINO Toolkit to run the myriad_compile.exe without building from source.
Syamimi
Syamimi_Intel
Hi franva,
Thank you for reaching out. The supported values for -ip of myriad_compile tool is FP32, FP16 and U8. Have a look on the attached picture:
For your information, Luxonis MyriadX Blob Converter is not a part of OpenVINO Toolkit. If you have any further question, you may open a new thread in Luxonis Discussion or GitHub blobconverter.
Syamimi
franva
Thanks  @Syamimi_Intel
The picture is broken, could you kindly update it again?
Cheers,
Winston
Syamimi_Intel
Hi franva,
Re-attach the photo:
Syamimi
franva
thanks @Syamimi_Intel  Is the Myriad_compile.exe a part of OpenVINO?
Will I be able to get it from Github?
If yes, could you please provide the link?
Thank you very much.
Winston
Syamimi_Intel
Hi Franva,
Syamimi
Syamimi_Intel
Hi Franva,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Syamimi
