6594 Discussions
When using the TF data api and iterators, how do you name the input?
Here is how I input data into my network:
iterator = TFRecordParser.input_fn(batch_size, record_path)
sess.run(iterator.initializer)
image, ground_truth = iterator.get_next()
prediction = network(image)
So "image" is the data going into my network, and "prediction" is the output. How do I name these so that I can compile with mvNCCompile?
Nevermind, I figured it out. Basically, when you go to make your inference only python file, you have to delete the iterator code anyways because you don't need it. So just replace
with
image = tf.placeholder(tf.float32, [None, 480, 640, 3], name="input")
even if you didn't use the feed_dict pattern.
