6594 Discussions
Working YoloV3-tiny model outputs garbage on NCS2
Trost__David
We trained a custom 1 class yolov3-tiny model using our dataset of ~3k images. (see config file below) converted to .pb and then converted to .xml and .bin successfully.  However when we run inference on the NCS2 (which is attached to a Rasberry Pi 3 B with Rasbian Stretch) the output is garbage, showing dozens of detections constantly often with bounding boxes that are perfectly flat.  The original darknet model does not do this and we have confirmed detects our class consistently and accurately.  We are at a loss as to what could be the problem and have been working on this issues for over a week and could really use some help.
Additionally we tested the .pb file in the intermediate step of the conversion process and were able to detect our class with that. Below is the commands used, then the config file and json file and the python script used for inference. I have also attached an image of our garbage output.
COMMANDS
./darknet partial cfg/yolov3-tiny-goose.cfg yolov3-tiny.weights goose-weights.conv.15 15
./darknet detector train goose.data cfg/yolov3-tiny-goose.cfg goose-weights.conv.15
python3 convert_weights_pb.py --class_names goose.names --weights_file yolov3-tiny-goose_final.weights --data_format NHWC --tiny
sudo python3 /opt/intel/computer_vision_sdk/deployment_tools/model_optimizer/mo_tf.py --input_model frozen_darknet_yolov3_model.pb --output_dir lrmodels/tiny-YoloV3/FP16 --data_type FP16 --batch 1 --tensorflow_use_custom_operations_config yolov3_goose4.json
CONFIG FILE
[net]
# Testing
batch=24
subdivisions=8
# Training
# batch=64
# subdivisions=2
width=416
height=416
channels=3
momentum=0.9
decay=0.0005
angle=0
saturation = 1.5
exposure = 1.5
hue=.1
learning_rate=0.001
burn_in=1000
max_batches = 500200
policy=steps
steps=400000,450000
scales=.1,.1
[convolutional]
batch_normalize=1
filters=16
size=3
stride=1
pad=1
activation=leaky
[maxpool]
size=2
stride=2
[convolutional]
batch_normalize=1
filters=32
size=3
stride=1
pad=1
activation=leaky
[maxpool]
size=2
stride=2
[convolutional]
batch_normalize=1
filters=64
size=3
stride=1
pad=1
activation=leaky
[maxpool]
size=2
stride=2
[convolutional]
batch_normalize=1
filters=128
size=3
stride=1
pad=1
activation=leaky
[maxpool]
size=2
stride=2
[convolutional]
batch_normalize=1
filters=256
size=3
stride=1
pad=1
activation=leaky
[maxpool]
size=2
stride=2
[convolutional]
batch_normalize=1
filters=512
size=3
stride=1
pad=1
activation=leaky
[maxpool]
size=2
stride=1
[convolutional]
batch_normalize=1
filters=1024
size=3
stride=1
pad=1
activation=leaky
[convolutional]
batch_normalize=1
filters=256
size=1
stride=1
pad=1
activation=leaky
[convolutional]
batch_normalize=1
filters=512
size=3
stride=1
pad=1
activation=leaky
[convolutional]
size=1
stride=1
pad=1
filters=18
activation=linear
[yolo]
mask = 3,4,5
anchors = 10,14,  23,27,  37,58,  81,82,  135,169,  344,319
classes=1
num=6
jitter=.3
ignore_thresh = .7
truth_thresh = 1
random=1
[route]
layers = -4
[convolutional]
batch_normalize=1
filters=128
size=1
stride=1
pad=1
activation=leaky
[upsample]
stride=2
[route]
layers = -1, 8
[convolutional]
batch_normalize=1
filters=256
size=3
stride=1
pad=1
activation=leaky
[convolutional]
size=1
stride=1
pad=1
filters=18
activation=linear
[yolo]
mask = 0,1,2
classes=1
num=6
jitter=.3
ignore_thresh = .7
truth_thresh = 1
random=1
JSON FILE
    "id": "TFYOLOV3",
    "match_kind": "general",
    "custom_attributes": {
      "classes": 1,
      "coords": 4,
      "num": 6,
      "mask": [0,1,2],
      "anchors":[10,14,23,27,37,58,81,82,135,169,344,319],
      "entry_points": ["detector/yolo-v3-tiny/Reshape","detector/yolo-v3-tiny/Reshape_4"]
INFERENCE SCRIPT
import sys, os, cv2, time, heapq, argparse
import numpy as np, math
from openvino.inference_engine import IENetwork, IEPlugin
import multiprocessing as mp
from time import sleep
import threading
yolo_scale_13 = 13
yolo_scale_26 = 26
yolo_scale_52 = 52
classes = 1
coords = 4
num = 3
anchors = [10,14, 23,27, 37,58, 81,82, 135,169, 344,319]
LABELS = ("goose")
label_text_color = (255, 255, 255)
label_background_color = (125, 175, 75)
box_color = (255, 128, 0)
box_thickness = 1
processes = []
fps = ""
detectfps = ""
framecount = 0
detectframecount = 0
time1 = 0
time2 = 0
lastresults = None
def EntryIndex(side, lcoords, lclasses, location, entry):
    n = int(location / (side * side))
    loc = location % (side * side)
    return int(n * side * side * (lcoords + lclasses + 1) + entry * side * side + loc)
class DetectionObject():
    xmin = 0
    ymin = 0
    xmax = 0
    ymax = 0
    class_id = 0
    confidence = 0.0
    def __init__(self, x, y, h, w, class_id, confidence, h_scale, w_scale):
        self.xmin = int((x - w / 2) * w_scale)
        self.ymin = int((y - h / 2) * h_scale)
        self.xmax = int(self.xmin + w * w_scale)
        self.ymax = int(self.ymin + h * h_scale)
        self.class_id = class_id
        self.confidence = confidence
def IntersectionOverUnion(box_1, box_2):
    width_of_overlap_area = min(box_1.xmax, box_2.xmax) - max(box_1.xmin, box_2.xmin)
    height_of_overlap_area = min(box_1.ymax, box_2.ymax) - max(box_1.ymin, box_2.ymin)
    area_of_overlap = 0.0
    if (width_of_overlap_area < 0.0 or height_of_overlap_area < 0.0):
    else:
        area_of_overlap = width_of_overlap_area * height_of_overlap_area
    box_1_area = (box_1.ymax - box_1.ymin)  * (box_1.xmax - box_1.xmin)
    box_2_area = (box_2.ymax - box_2.ymin)  * (box_2.xmax - box_2.xmin)
    area_of_union = box_1_area + box_2_area - area_of_overlap
    retval = 0.0
    if area_of_union <= 0.0:
        retval = 0.0
    else:
        retval = (area_of_overlap / area_of_union)
    return retval
def ParseYOLOV3Output(blob, resized_im_h, resized_im_w, original_im_h, original_im_w, threshold, objects):
    out_blob_h = blob.shape[2]
    out_blob_w = blob.shape[3]
    side = out_blob_h
    anchor_offset = 0
    if side == yolo_scale_13:
        anchor_offset = 2 * 3
    elif side == yolo_scale_26:
        anchor_offset = 2 * 0
    side_square = side * side
    output_blob = blob.flatten()
    for i in range(side_square):
        row = int(i / side)
        col = int(i % side)
        for n in range(num):
            obj_index = EntryIndex(side, coords, classes, n * side * side + i, coords)
            box_index = EntryIndex(side, coords, classes, n * side * side + i, 0)
            scale = output_blob[obj_index]
            if (scale < threshold):
                continue
            x = (col + output_blob[box_index + 0 * side_square]) / side * resized_im_w
            print("box_index:",box_index)
            print("output_blob:",output_blob[box_index + 0 * side_square])
            y = (row + output_blob[box_index + 1 * side_square]) / side * resized_im_h
            height = math.exp(output_blob[box_index + 3 * side_square]) * anchors[anchor_offset + 2 * n + 1]
            width = math.exp(output_blob[box_index + 2 * side_square]) * anchors[anchor_offset + 2 * n]
            for j in range(classes):
                class_index = EntryIndex(side, coords, classes, n * side_square + i, coords + 1 + j)
                prob = scale * output_blob[class_index]
                if prob < threshold:
                    continue
                obj = DetectionObject(x, y, height, width, j, prob, (original_im_h / resized_im_h), (original_im_w / resized_im_w))
                #print(x, y, height, width, j, prob, (original_im_h / resized_im_h), (original_im_w / resized_im_w))
                objects.append(obj)
    return objects
def ParseTest(blob, resized_im_h, resized_im_w, original_im_h, original_im_w, threshold, objects):
    side = 13
    anchor_offset = 6
    output_blob = blob
        row = int(i / side)
        col = int(i % side)
            print("x " + str(output_blob[0][n+0][row][col]) + " y " + str(output_blob[0][n+1][row][col]) + " w " + str(output_blob[0][n+2][row][col]) + " h " + str(output_blob[0][n+3][row][col]) + " prob " + str(output_blob[0][n+4][row][col]) + " class " + str(output_blob[0][n+5][row][col]))
        print()
    return objects
def camThread(LABELS, results, frameBuffer, camera_width, camera_height, vidfps):
    global fps
    global detectfps
    global lastresults
    global framecount
    global detectframecount
    global time1
    global time2
    global cam
    global window_name
    cam = cv2.VideoCapture(0)
    if cam.isOpened() != True:
        print("USB Camera Open Error!!!")
        sys.exit(0)
    cam.set(cv2.CAP_PROP_FPS, vidfps)
    cam.set(cv2.CAP_PROP_FRAME_WIDTH, camera_width)
    cam.set(cv2.CAP_PROP_FRAME_HEIGHT, camera_height)
    window_name = "USB Camera"
    wait_key_time = 1
    #cam = cv2.VideoCapture("data/input/testvideo4.mp4")
    #camera_width = int(cam.get(cv2.CAP_PROP_FRAME_WIDTH))
    #camera_height = int(cam.get(cv2.CAP_PROP_FRAME_HEIGHT))
    #frame_count = int(cam.get(cv2.CAP_PROP_FRAME_COUNT))
    #window_name = "Movie File"
    #wait_key_time = int(1000 / vidfps)
    cv2.namedWindow(window_name, cv2.WINDOW_AUTOSIZE)
    while True:
        t1 = time.perf_counter()
        # USB Camera Stream Read
        #     should be: cam.read()
        s, color_image = cam.read()
        if not s:
            continue
        if frameBuffer.full():
            frameBuffer.get()
        height = color_image.shape[0]
        width = color_image.shape[1]
        frameBuffer.put(color_image.copy())
        if not results.empty():
            objects = results.get(False)
            detectframecount += 1
            for obj in objects:
                if obj.confidence < 0.2:
                    continue
                label = obj.class_id
                confidence = obj.confidence
                if confidence > 0.2:
                    label_text = LABELS[label] + " (" + "{:.1f}".format(confidence * 100) + "%)"
                    cv2.rectangle(color_image, (obj.xmin, obj.ymin), (obj.xmax, obj.ymax), box_color, box_thickness)
                    cv2.putText(color_image, label_text, (obj.xmin, obj.ymin - 5), cv2.FONT_HERSHEY_SIMPLEX, 0.6, label_text_color, 1)
            lastresults = objects
        else:
            if not isinstance(lastresults, type(None)):
                for obj in lastresults:
                        continue
        cv2.putText(color_image, fps,       (width-170,15), cv2.FONT_HERSHEY_SIMPLEX, 0.5, (38,0,255), 1, cv2.LINE_AA)
        cv2.putText(color_image, detectfps, (width-170,30), cv2.FONT_HERSHEY_SIMPLEX, 0.5, (38,0,255), 1, cv2.LINE_AA)
        cv2.imshow(window_name, cv2.resize(color_image, (width, height)))
        if cv2.waitKey(wait_key_time)&0xFF == ord('q'):
            sys.exit(0)
        ## Print FPS
        framecount += 1
        if framecount >= 15:
            fps       = "(Playback) {:.1f} FPS".format(time1/15)
            detectfps = "(Detection) {:.1f} FPS".format(detectframecount/time2)
            framecount = 0
            time1 = 0
            time2 = 0
        t2 = time.perf_counter()
        elapsedTime = t2-t1
        time1 += 1/elapsedTime
        time2 += elapsedTime
# l = Search list
# x = Search target value
def searchlist(l, x, notfoundvalue=-1):
    if x in l:
        return l.index(x)
    else:
        return notfoundvalue
def async_infer(ncsworker):
    #ncsworker.skip_frame_measurement()
    while True:
        ncsworker.predict_async()
class NcsWorker(object):
    def __init__(self, devid, frameBuffer, results, camera_width, camera_height, number_of_ncs, vidfps):
        self.devid = devid
        self.frameBuffer = frameBuffer
        self.model_xml = "./lrmodels/tiny-YoloV3/FP16/frozen_darknet_yolov3_model.xml"
        self.model_bin = "./lrmodels/tiny-YoloV3/FP16/frozen_darknet_yolov3_model.bin"
        self.camera_width = camera_width
        self.camera_height = camera_height
        self.m_input_size = 416
        self.threshould = 0.8
        self.num_requests = 4
        self.inferred_request = [0] * self.num_requests
        self.heap_request = []
        self.inferred_cnt = 0
        self.plugin = IEPlugin(device="MYRIAD")
        self.net = IENetwork(model=self.model_xml, weights=self.model_bin)
        self.input_blob = next(iter(self.net.inputs))
        self.exec_net = self.plugin.load(network=self.net, num_requests=self.num_requests)
        self.results = results
        self.number_of_ncs = number_of_ncs
        self.predict_async_time = 800
        self.skip_frame = 0
        self.roop_frame = 0
        self.vidfps = vidfps
        self.new_w = int(camera_width * min(self.m_input_size/camera_width, self.m_input_size/camera_height))
        self.new_h = int(camera_height * min(self.m_input_size/camera_width, self.m_input_size/camera_height))
    def image_preprocessing(self, color_image):
        resized_image = cv2.resize(color_image, (self.new_w, self.new_h), interpolation = cv2.INTER_CUBIC)
        canvas = np.full((self.m_input_size, self.m_input_size, 3), 128)
        canvas[(self.m_input_size-self.new_h)//2:(self.m_input_size-self.new_h)//2 + self.new_h,(self.m_input_size-self.new_w)//2:(self.m_input_size-self.new_w)//2 + self.new_w,  :] = resized_image
        prepimg = canvas
        prepimg = prepimg[np.newaxis, :, :, :]     # Batch size axis add
        prepimg = prepimg.transpose((0, 3, 1, 2))  # NHWC to NCHW
        return prepimg
    def skip_frame_measurement(self):
            surplustime_per_second = (1000 - self.predict_async_time)
            if surplustime_per_second > 0.0:
                frame_per_millisecond = (1000 / self.vidfps)
                total_skip_frame = surplustime_per_second / frame_per_millisecond
                self.skip_frame = int(total_skip_frame / self.num_requests)
            else:
                self.skip_frame = 0
    def predict_async(self):
        try:
            if self.frameBuffer.empty():
                return
            self.roop_frame += 1
            if self.roop_frame <= self.skip_frame:
               self.frameBuffer.get()
               return
            self.roop_frame = 0
            prepimg = self.image_preprocessing(self.frameBuffer.get())
            reqnum = searchlist(self.inferred_request, 0)
            #print("image transformed")
            #print(reqnum)
            if reqnum > -1:
                #print("srting IEPluggin")
                self.exec_net.start_async(request_id=reqnum, inputs={self.input_blob: prepimg})
                self.inferred_request[reqnum] = 1
                self.inferred_cnt += 1
                if self.inferred_cnt == sys.maxsize:
                    #print("if ran")
                heapq.heappush(self.heap_request, (self.inferred_cnt, reqnum))
                #print("heap pushed")
                #print(reqnum)
            cnt, dev = heapq.heappop(self.heap_request)
            if self.exec_net.requests[dev].wait(0) == 0:
                #print("if")
                self.exec_net.requests[dev].wait(-1)
                objects = []
                outputs = self.exec_net.requests[dev].outputs
                for output in outputs.values():
                    # change this
                    objects = ParseYOLOV3Output(output, self.new_h, self.new_w, self.camera_height, self.camera_width, self.threshould, objects)
                objlen = len(objects)
                for i in range(objlen):
                    if (objects.confidence == 0.0):
                        continue
                    for j in range(i + 1, objlen):
                        if (IntersectionOverUnion(objects, objects) >= 0.4):
                            if objects.confidence < objects.confidence:
                                objects, objects = objects, objects
                            objects.confidence = 0.0
                self.results.put(objects)
                self.inferred_request[dev] = 0
            else:
                #print("else")
                heapq.heappush(self.heap_request, (cnt, dev))
        except:
            import traceback
            traceback.print_exc()
def inferencer(results, frameBuffer, number_of_ncs, camera_width, camera_height, vidfps):
    # Init infer threads
    threads = []
    for devid in range(number_of_ncs):
        thworker = threading.Thread(target=async_infer, args=(NcsWorker(devid, frameBuffer, results, camera_width, camera_height, number_of_ncs, vidfps),))
        thworker.start()
        threads.append(thworker)
    for th in threads:
        th.join()
if __name__ == '__main__':
    parser = argparse.ArgumentParser()
    parser.add_argument('-numncs','--numberofncs',dest='number_of_ncs',type=int,default=1,help='Number of NCS. (Default=1)')
    args = parser.parse_args()
    number_of_ncs = args.number_of_ncs
    camera_width = 320
    camera_height = 240
    vidfps = 30
    try:
        mp.set_start_method('forkserver')
        frameBuffer = mp.Queue(10)
        results = mp.Queue()
        # Start detection MultiStick
        # Activation of inferencer
        p = mp.Process(target=inferencer, args=(results, frameBuffer, number_of_ncs, camera_width, camera_height, vidfps), daemon=True)
        p.start()
        processes.append(p)
        sleep(number_of_ncs * 7)
        # Start streaming
        p = mp.Process(target=camThread, args=(LABELS, results, frameBuffer, camera_width, camera_height, vidfps), daemon=True)
        p.start()
        processes.append(p)
        while True:
            sleep(1)
    except:
        import traceback
    finally:
        for p in range(len(processes)):
            processes
.terminate()
        print("\n\nFinished\n\n")
Shubha_R_Intel
Dear David, the number of classes being just 1 is very suspect. See our default yolo_v3_tiny.json found under C:\Program Files (x86)\IntelSWTools\openvino_2019.1.087\deployment_tools\model_optimizer\extensions\front\tf (if you are using Windows 10):
    "id": "TFYOLOV3",
      "classes": 80,
      "anchors": [10, 14, 23, 27, 37, 58, 81, 82, 135, 169, 344, 319],
      "coords": 4,
      "num": 6,
      "mask": [0, 1, 2],
      "entry_points": ["detector/yolo-v3-tiny/Reshape", "detector/yolo-v3-tiny/Reshape_4"]
Why are you restricting the number of classes to 1 ?
As This forum poster noticed, increasing the number of classes to 80 improves detection.
Hope it helps. Thanks for using OpenVino !
Shubha
Kim__Sangmin
Hi David :)
I have the same issue.
I want to run my custom model that I trained. And I set classes to 2. Because I made two data training models.
If you have solved it, please comment ...
Thank you
Shubha_R_Intel
Dear Kim, Sangmin and David, the forum poster I referred to above improved his yolo3 by upgrading to 2019 R1. He had a similar issue to you. Are you using OpenVino 2019 R1 ?
Shubha
