YOLO: Error Converting YOLOv3 Model
gomes__antonio
hello,
I am trying to convert the YOLO model to tensorflow but when I run demo.py file it returns this error:
C:\Intel\computer_vision_sdk_2018.5.445\deployment_tools\intel_models\tensorflow-yolo-v3>demo.py --weights_file C:\Intel\computer_vision_sdk_2018.5.445\deployment_tools\intel_models\tensorflow-yolo-v3\yolov3.weights --class_names C:\Intel\computer_vision_sdk_2018.5.445\deployment_tools\intel_models\tensorflow-yolo-v3\coco.names.txt --input_img C:\Intel\computer_vision_sdk_2018.5.445\deployment_tools\intel_models\tensorflow-yolo-v3\trafico.jpg --output_img ./out.jpg
Traceback (most recent call last):
  File "C:\Users\andre\AppData\Roaming\Python\Python36\site-packages\tensorflow\python\pywrap_tensorflow.py", line 58, in <module>
    from tensorflow.python.pywrap_tensorflow_internal import *
  File "C:\Users\andre\AppData\Roaming\Python\Python36\site-packages\tensorflow\python\pywrap_tensorflow_internal.py", line 28, in <module>
    _pywrap_tensorflow_internal = swig_import_helper()
  File "C:\Users\andre\AppData\Roaming\Python\Python36\site-packages\tensorflow\python\pywrap_tensorflow_internal.py", line 24, in swig_import_helper
    _mod = imp.load_module('_pywrap_tensorflow_internal', fp, pathname, description)
  File "C:\Users\andre\AppData\Local\Programs\Python\Python36\lib\imp.py", line 243, in load_module
    return load_dynamic(name, filename, file)
  File "C:\Users\andre\AppData\Local\Programs\Python\Python36\lib\imp.py", line 343, in load_dynamic
    return _load(spec)
ImportError: DLL load failed:A dynamic link library (DLL) initialization routine failed.
During handling of the above exception, another exception occurred:
  File "C:\Intel\computer_vision_sdk_2018.5.445\deployment_tools\intel_models\tensorflow-yolo-v3\demo.py", line 4, in <module>
    import tensorflow as tf
  File "C:\Users\andre\AppData\Roaming\Python\Python36\site-packages\tensorflow\__init__.py", line 24, in <module>
    from tensorflow.python import pywrap_tensorflow  # pylint: disable=unused-import
  File "C:\Users\andre\AppData\Roaming\Python\Python36\site-packages\tensorflow\python\__init__.py", line 49, in <module>
  File "C:\Users\andre\AppData\Roaming\Python\Python36\site-packages\tensorflow\python\pywrap_tensorflow.py", line 74, in <module>
    raise ImportError(msg)
ImportError: Traceback (most recent call last):
    return _load(spec)
ImportError: DLL load failed: A dynamic link library (DLL) initialization routine failed..
Is this related to the tensorflow version?????
tensorflow version:1.12.0
Shubha_R_Intel
gomes__antonio
Hello Shubha. Thanks for reply.
Yes, I followed this.
The problem is in the tensorflow version.
